Mortar On Concrete Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-22-2012, 11:14 PM   #1
Rewards Points: 12
Mortar on concrete slab
I am building a slop shower pan with mortar. Should I add concrete glue to the mortar for it to bond to the concrete.
gbonin is offline   Reply With Quote
Old 04-22-2012, 11:41 PM   #2
Rewards Points: 1,092
it's likely best to ask at a local concrete place. they should have the answers and the materials. what you propose does not sound like the proper attack, but i am not a concrete guy.
Old 04-23-2012, 07:01 AM   #3
Generally if the concrete is clean the cement in your "mortar?" will bond. Many times they recommend you acid wash the concrete to insure it is clean.
It more than likely is no better bond than say tile if you tried really hard you would be able to separate it. I am not sure it matters a lot. Most showers pans built like this use 2 layers of concrete with a rubber like layer between them. The top layer of concrete seems to have no issues even though I can't see how it would ever bond to a smooth waterproof membrane.
bill01 is offline   Reply With Quote
The Following User Says Thank You to bill01 For This Useful Post:
jomama45 (04-23-2012)
Old 04-24-2012, 07:26 AM   #4
Rewards Points: 152
Mortar will easily bond to concrete. Sounds like your building this shower pan on a slab? Not sure where your getting your ideas or info from but you must propery install the rubber membrane underneath the shower pan. If your using mortar (not recommended) then it should never come in contact with the concrete below.
TRUEPRO is offline   Reply With Quote
Old 04-24-2012, 09:49 AM   #5
Concrete & Masonry
Rewards Points: 568
It's called a "pre-slope", and it get's poured below the rubber so any possible leaks actually find their way to the weeps in the drain.............
Or, it's just a simple "slop" shower in his/her garage for a dog or something.....
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
TRUEPRO (04-24-2012)
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 10:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 03:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 10:37 AM
