Mortar Color - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-23-2015, 04:22 PM   #1
Rewards Points: 396
Mortar color
I need to repoint some bricks and would like to know a good way to lighten the mortar color so I can get it to match the surrounding bricks?
detroittigerfan is offline   Reply With Quote
Old 04-23-2015, 06:14 PM   #2
Rewards Points: 12,876
Go to a real masonry supply and pick up a sample kit.
There likly going to have a match in stock, so no need for any mixing.
A picture of what you have may help.
Old 04-24-2015, 10:14 AM   #3
Rewards Points: 1,220
I work at a real masonry supply, and you will not get a sample kit as a homeowner. What I tell people to do that come in for a non-pigmented mortar is to buy a bag of white and a bag of grey masonry cement and blend. Then rub some dirt on it for the match.
For pigmented mortars, it is even more difficult.
The reality is that it is almost impossible to do "touch up" grade matches. Professionals go corner to corner or edge to edge, thus eliminating the issue of a close match.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following 2 Users Say Thank You to Tscarborough For This Useful Post:
oh'mike (04-24-2015), stadry (04-24-2015)
Old 06-13-2015, 12:22 AM   #4
Rewards Points: 4
If you finished the job and the colors are not matching, you can dye the mortar after it has cured long enough. We have a chimney on our house that had two different mortar colors. We wanted to change the color of the mortar so it was all the same and I found a product online called Instant Mortar Match. We just brushed it on. It was pretty simple to do.
diy_enthusiast is offline   Reply With Quote
Issues with Paint Sample color and Gallon Color - need advice 7 VII 7 Painting 22 05-07-2013 09:19 AM
Replace mortar between stones in fireplace hearth support dm1337 Concrete, Stone & Masonry 3 06-17-2012 11:41 AM
Wall color Debbie1234 Interior Decorating 3 01-24-2012 01:40 PM
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 08:27 PM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 08:52 AM
