Mortar For CMU Wall? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-03-2012, 02:47 AM   #1
Mortar for CMU wall?
What mix should i use for foundations, to build garden walling, 1.5 mtrs high (concrete blocks)
Emma123 is offline   Reply With Quote
Old 08-03-2012, 07:04 AM   #2
Rewards Points: 502
1:2:4 cement:sand;aggregate should be OK. What is more important is depth and size of foundation.
tony.g is offline   Reply With Quote
Old 08-03-2012, 11:39 PM   #3
Registered User
Rewards Points: 5,514
Welcome to the forums! I moved you to "Concrete" for more responses.
Gary
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 10:28 PM
Stone wall problem with mortar weberus3 Building & Construction 22 01-06-2010 08:06 AM
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 09:39 AM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 08:22 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
