Mortar In Blocks - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-10-2013, 01:45 PM   #1
Rewards Points: 33
Mortar in blocks
I own a home built in 1935 in Pittsburgh, PA.
I noticed a few places on the blocks of my foundation where the mortar is falling out (seemingly due to weathering). I've read that repairing the mortar between bricks of this age requires a certain type of mortar, and that buying modern mortar will damage the brick due to differing rates of expansion and contraction. Is this the case with the cement blocks of my foundation? I purchased a bucket of cement patch before reading the above, and wanted to check before I start filling cracks and holes.
venator260 is offline   Reply With Quote
Old 09-10-2013, 02:02 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
The problem only exists with brick and not block.
You just need to clean out joint and then tuck point with a Type N mortar. You can start with a bag of pre-proportioned Type N mortar.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Replace mortar between stones in fireplace hearth support dm1337 Concrete, Stone & Masonry 3 06-17-2012 11:41 AM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 08:52 AM
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 08:44 AM
tree roots raising block wall/loosening mortar Pawl Building & Construction 16 09-10-2011 09:38 AM
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 12:13 PM
