Mold/mildew Control On Cinder Block Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-25-2013, 11:59 AM   #1
Rewards Points: 1,010
Mold/mildew control on cinder block wall
I'm currently redoing the (exterior facing) walls in my basement. I found the previous owners put up fiberglass batt insulation and covered that with plastic sheeting for insulation. As you can guess, there was mold and mildew growing where the paper facing of the batt met up against the plastic sheeting.
I tore that all out and checked the wall behind it. Fortunately there are no signs of water damage or leaks, and no signs of mold or mildew on the block wall. But I still want to prep/clean the walls before I redo the insulation (XPS foam boards) and put up new studs.
The walls do appear to have already been coated with two coats of paint or water sealant. Should I use a spray type mold and mildew cleaner, or should I coat the walls with a mold and mildew resistant primer? Or both?
spaceman spif is offline   Reply With Quote
Old 03-25-2013, 07:18 PM   #2
Rewards Points: 3,358
You should be able to get this at Home Depot,just follow the directions,and see what it looks like when your through.
http://www.plumbersurplus.com/Prod/M...FQk4nAodgz8Aew
Canarywood1 is online now   Reply With Quote
Old 03-27-2013, 09:09 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
If you don't have any mold, then don't apply a fungicide. It won't provide any lasting mold resistant qualities. Instead apply some paint or primer with mold inhibitors in it. See the link below for an example. However, if you have a moisture issue, even this is could be short lived protection.
http://rustoleum.com/CBGProduct.asp?pid=346
Question regarding new load center on cinder block wall. chris_b Electrical 11 02-28-2013 04:56 PM
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 11:22 PM
Repair pitting in cinder block wall.... stupid48 General DIY Discussions 10 02-01-2012 01:06 AM
Creating passageway through cinder block wall ...? mark_p Building & Construction 7 09-14-2009 09:22 AM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 10:34 PM
