Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-22-2012, 12:31 AM   #1
moisture barrier
Is a moisture barrier necessary on a dry stack exterior wall?
Dave Filson is offline   Reply With Quote
Old 10-22-2012, 08:07 AM   #2
moisture barrier
Many municipal codes require a moisture barrier no matter what the exterior uses. You can than Tyvek for that. Some municipal codes even mandate that brand name.
riddlers is offline   Reply With Quote
moisture barrier question in crawlspace Peggy Kapral Building & Construction 3 10-04-2012 08:41 AM
Air barrier moisture barrier ? Faced vs unfaced insulation ? Wind82 Building & Construction 6 03-02-2012 01:00 PM
Help with moisture barrier Aloha1 General Discussion 2 10-25-2011 07:44 AM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Moisture barrier for framing pennshaq Remodeling 0 07-02-2010 08:45 AM
