Mira-drain For Retaining Wall??? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-11-2012, 09:08 PM   #1
mira-drain for retaining wall???
Im re-doing a failed retaining wall and will be done with poured concrete and finished with stucco after. My question is because the property is located on a hillside, I don't want to haul buckets and buckets of crushed gravel up 50+ steps. Can mira-drain filter fabric be used with no gravel behind the wall?? I can only go up 3' above grade before I need a design review and engineered plans.
djk888 is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Retaining Wall & Drain Tile Help minnesota Landscaping & Lawn Care 0 03-28-2012 10:27 PM
P Trap to wall waste Drain - Newbie plumber homeboyslim Plumbing 1 05-09-2011 04:02 PM
Changing floor drain to wall drain nitting Plumbing 1 04-15-2011 10:16 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
