Metal Squares On Brick Buildings? Are They For Structure? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-05-2012, 04:57 PM   #1
Rewards Points: 209
Metal squares on brick buildings? Are they for structure?
I was wondering about those metal squares that you see on older brick buildings. Does anyone know what they are for?
They look kind of decorative but they are usually 4 inch by 4 inch. They sometimes look like there's a small circle in the middle of them like a bolt or something?
I was wondering if they are screwed in and bolted into wall to help keep the bricks from falling out
If anyone could help that would be great.
here's an example of the squares they're on the top right
http://www.dreamstime.com/large-gree...mb13047452.jpg
also on the top of this building
http://firstlisting.com/images/brick-building.jpg
crayola110 is offline   Reply With Quote
Old 10-05-2012, 05:04 PM   #2
Rewards Points: 13,260
There to keep the wall from bowing out and to hold the brick in place toward the middle of the wall.
Now they use brick ties to keep the brick in place that area attached to the wall behind the brick where you can not see them.
Old 10-05-2012, 05:26 PM   #3
Rewards Points: 209
Thanks Joe, I just was adding links to my post when I saw yours.
Do you know the name of the squares?
I was looking at an older building. One of the walls started having bricks fall and it did end up bowing out onto the street. It cost about $10K just to tear it all down and stucco it.
On the other side of the building there's no bowing, but I wanted to reinforce it so the bowing does not happen. I thought maybe I could install these squares or perhaps the brick tie you are talking about to reinforce the walls? Also would epoxy help reinforce it if there are some small cracks in the mortar lines of the brick or anything else you would suggest?
Below are pictures of the opposite wall on the side of the building. It has been painted because the brick is rather old. Could there be slight bowing? Would these squares help reinforce the walls so they won't bow?
Metal squares on brick buildings? Are they for structure?-photo-11-.jpg   Metal squares on brick buildings? Are they for structure?-photo-12-.jpg
Old 10-05-2012, 06:05 PM   #4
concretemasonry's Avatar
Rewards Points: 2,578
It all depends on whether they are true brick walls or just real brick veneer walls.
In seismic areas (like SoCAL) they are frequently used to strengthen the walls for seismic EVENTS.
If the walls are brick veneer they could be to maintain stability if there were not adequate or corroded.
When I lived in SoCal, the only EVENTS you could plan on were the Rose Bowl parade and game. Now, I am where (MN) we have predicted EVENTS like blizzards and can schedule big parties and no one is disappointed of the snow and wind does not come.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
crayola110 (10-05-2012)
Old 10-05-2012, 06:07 PM   #5
Rewards Points: 582
They are called pattress plates. Half the houses round here would be in ruins without them.
http://www.redgwick.co.uk/
stuart45 is offline   Reply With Quote
The Following User Says Thank You to stuart45 For This Useful Post:
tony.g (10-13-2012)
Old 10-05-2012, 06:15 PM   #6
Rewards Points: 209
Dick
I think they are brick veneer as you said, Dick. They are not as deep as a normal brick is. They are not very thick. Probably half or a third the thickness of a normal brick. I'm almost positive they are not structural because they're not full bricks. Or could they be?
So would patress plates (thanks stuart) be good for holding them in and preventing any bowing?
Old 10-05-2012, 06:24 PM   #7
Rewards Points: 582
Pattress plates used with tie bars are really for holding in solid masonry walls. A more modern method is shown here.
tony.g (10-06-2012)
Old 10-12-2012, 03:58 PM   #8
Rewards Points: 209
What could you recommend for keeping the veneer walls from cracking and bowing? Is there a patch or should I use the Patress squares or anchors?
wrought iron security door frame diy888 Windows and Doors 6 02-22-2016 08:08 AM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 09:09 PM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 03:22 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
