Maximum Pressure On Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-09-2013, 04:29 AM   #1
maximum Pressure on floor
Hello fellow DEE AYE WIRES...
I am in search of some information on maximum floor loads (force per unit area) for varying floor types, in order to choose the correct wheel type. For example, some concrete floors can take 8N/mm2 of pressure others can take 12N/mm2.
I would be very gratetful if someone could point me in the direction of a chart of floor types with their associated maximum force/unit area ratings. Actually any info at all on the subject would be great!
Might be a tough one as I can't find anything on the intertron. Looking forward to hearing from you... Thanks.
crocklip is offline   Reply With Quote
Old 01-09-2013, 06:33 AM   #2
DIY staff
Rewards Points: 7,174
I moved this to building and construction--this is an engineering question---
What was the comment about wheels?
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Bridging--bouncy vibrating floor meature Building & Construction 15 02-05-2013 05:43 PM
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 05:36 PM
Well Pump Pressure Problems LTY83 Plumbing 15 06-30-2012 02:58 PM
Heating question, negative pressure 2nd floor Shamus HVAC 8 10-04-2008 11:24 AM
