Masonry Work In Low Temps - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-05-2012, 02:11 AM   #1
Rewards Points: 1,062
Question
masonry work in low temps
is there a common low temp below which masonry work should be avoided, like 40 F ?
e.g. i just did some brick work and about 4 hr later the temps got below 40. is that bad?
thanks
Old 03-05-2012, 04:51 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Anything above freezing.
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
amakarevic (03-05-2012)
Old 03-05-2012, 06:04 AM   #3
Gymschu's Avatar
Rewards Points: 218
It can be done in cold temps, but it sure is a hassle. Additives, covering your work so it doesn't freeze, etc.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 03-05-2012, 09:38 AM   #4
concretemasonry's Avatar
Rewards Points: 2,570
40F air temperature is no problem. Block basements here can be excavated and built at 0F.
A long as the mortar is not saturated when it freezes, there is no problem and your mortar did not freeze. Due to absorption of water by the brick and use of the water in the hydration of the cement, the mortar joints are not saturated after 6-12 hours of laying the brick. Any subsequent moisture and higher temperatures reactivates the curing of the mortar even if it has frozen.
Strength is also not a problem since weak mortar (compressive strength) is rare and the ASTM C270 specifications (Appendix 1) recommends to use the weakest mortar possible and still carry the load. Brick rarely carries any real load.
Dick
concretemasonry is offline   Reply With Quote
The Following 2 Users Say Thank You to concretemasonry For This Useful Post:
amakarevic (03-05-2012), Jay 78 (03-05-2012)
Old 03-05-2012, 01:49 PM   #5
Question
thanks everyone. how about painting masonry, can it be painted 12-24 hrs after laying or should i wait a few days to fully cure?
thanks
Old 03-05-2012, 02:01 PM   #6
Wait.
Dick
The Following User Says Thank You to concretemasonry For This Useful Post:
Old 03-05-2012, 02:06 PM   #7
Question
Originally Posted by concretemasonry View Post
Wait.
like how long?
Tags
freezing , masonry
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 04:19 PM
What Temps Should York AC Unit Be? - Is it Me or Does my AC kind of work? mrpman HVAC 7 07-24-2011 07:59 PM
New work vs Old work Tetranitrate Electrical 3 07-12-2011 09:19 AM
Time limit for getting work inspected? tigereye Electrical 8 12-22-2009 03:56 AM
Low Profile Masonry Receptacle box? Lovegasoline Electrical 0 12-02-2009 02:01 PM
