Masonry Siding: Can It Extend Up To The 2nd Floor? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-24-2012, 11:35 PM   #1
Rewards Points: 35
Masonry Siding: Can it extend up to the 2nd floor?
Is it possible to achieve this design? The issue that I'm questioning is how to attach the roof above the first floor windows and still have the 2nd floor masonry siding being supported on the foundation's brick ledge.
To my simple way of looking at this, either the roof is attached to the framing, thus breaking the column of masonry which rests on the brick ledge, or the masonry continues up to the second floor without interruption, thus all of it is supported on the brick ledge but now the roof has to be attached to the wall in some way that escapes me.
Can anyone shed some light on whether this is possible and what techniques are required?
AlexHouse is offline   Reply With Quote
Old 03-24-2012, 11:47 PM   #2
Rewards Points: 13,270
Looks like dry stacked Faux stone to me.
Do a key word search on it.
Old 03-25-2012, 12:19 AM   #3
Rewards Points: 35
Please excuse the rendering. It may look like faux stone but the design criteria calls for real stone built over a brick ledge on the foundation.
I suppose the easy solution is to have real stone on the first floor, built on the brick ledge and then transition to some type of concrete fake stone which is mortered right onto the wall surface and doesn't need a brick ledge. I'd rather not do this if there is a way of using real stone.
Old 03-25-2012, 12:47 AM   #4
Rewards Points: 940
I think you either do the masonry first, then build the roofs, attaching the ledger to the masonry, or you frame the roof first and run the masonry around the rafters.
If you run the masonry around the rafters, the ledger would be set-in so it doesn't interfere with the masonry coming up, then one would work up through the rafters (around).
It depends on the construction of the structure. Are the walls framed with lumber, or are they masonry, ICF, whatever getting a stone veneer later?
Can you dig that?
cleveman is offline   Reply With Quote
Old 03-25-2012, 01:29 AM   #5
Rewards Points: 35
Good! That makes sense to me. The walls are 2x6 lumber framed, so the inset ledger seems to be the way to go, now it's just a matter of firmly securing the ledger between the studs instead of onto the surface of the studs.
Old 03-25-2012, 10:31 AM   #6
Concrete & Masonry
Rewards Points: 526
The most common way to deal with that in my own past experiences is to stop the stone at the soffit, work 4" concrete block between the "truss bays" to the top of roof flashing and then start with stone again above the counter-flashing line. The reason for the block going so high is to allow a nice flat substrate to flash into, an a "reglet" is easier to cut into a level horizontal joint.
If you wanted to build it out differently there are other options, like only bringing the block or stone up every 4' or so and spanning the balance with a steel lintel/angle iron.
jomama45 is online now   Reply With Quote
Old 03-27-2012, 03:00 AM   #7
Rewards Points: 35
Thank you for the detailed explanation. I have a better understanding of what is involved now and this will help me in the design phase. I really want to avoid discovering problems too late after the fact.
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 10:32 PM
New siding up to existing soffit jtchavez Building & Construction 18 03-25-2012 10:48 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
