Masonry/Fireplace Sealing - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-26-2013, 08:34 PM   #1
Question
The fireplace in our home "crumbles" (not sure how else to describe it). The mortar and bricks are all secure and un-cracked, but the mantel & hearth needs dusting nearly every day because of all the debris that falls.
My thought is to somehow seal the bricks/mortar so that they will stop this crumbling, but I'm unsure of what products to use OR if this can/should even be done.
Any suggestions or guidance?
Last edited by Trying2Fixit; 08-27-2013 at 07:03 AM. Reason: Added additional info
Trying2Fixit is offline   Reply With Quote
Old 08-26-2013, 09:13 PM   #2
Rewards Points: 13,750
Falls from where? Got a picture?
Old 08-26-2013, 09:33 PM   #3
From what I can tell, the crumbs come from all over - not one specific area. This picture shows only a section of the mantel, but you get the idea. It's all across the mantel and also on the hearth/floor underneath - so I know it's falling from more of an area than just right above the mantel itself.
Masonry/Fireplace Sealing-mantle.jpg
Air sealing attic mmastran Insulation 11 05-25-2011 07:31 AM
sealing compound?! mmhendrie Electrical 1 07-18-2010 06:51 PM
Sealing basement floor/wall gap countryboy43 Building & Construction 7 06-12-2010 10:00 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
Grout lightened after sealing SueT Tiling, ceramics, marble 6 11-23-2008 08:58 PM
