Masonary Repair - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-21-2012, 06:44 PM   #1
masonary repair
is ther a masonary caulk you can use instead of tuck pointing
teddyp1 is offline   Reply With Quote
Old 05-21-2012, 07:32 PM   #2
Too Short? Cut it Again!
There are many masonry caulk materials but you still have to carve the failed mortar out of the way. You cannot, or at least you should not, caulk around fragmented mortar and expect much even with epoxy materials. And once you have all the old stuff out of the way, mortar is time proven and cheap compared to alternatives. Look at the Abatron online catalog for some concrete and masonry caulk type options.
Old 05-21-2012, 07:40 PM   #3
+1. ^^
I tried it once in an area of my side wall because I was in a hurry when I noticed the loose mortar.
It's holding fine but it looks like sh-t.
It doesn't match the rest of the wall. It looks like what it is - caulk. I will dig it out and do it right soon..
Evstarr is offline   Reply With Quote
Old 08-07-2012, 02:43 AM   #4
What is the procedure for grinding out and repointing mortar on some bricks? Thanks
rosie123 is offline   Reply With Quote
Old 08-07-2012, 05:46 AM   #5
Rewards Points: 502
Use a small (4") angle grinder (aka disc cutter). Hire or buy- they're quite cheap. Take care when doing the vertical joints"
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
oh'mike (08-07-2012)
Old 08-07-2012, 09:04 AM   #6
What would I need to watch out for when grinding out a vertical joint?
I have a few joints that are cracked pretty bad right under a couple windows, can't think of what this is actuall called, but it's angled away from the house, kind of like a sill.
OKDrew63 is offline   Reply With Quote
Old 08-07-2012, 10:12 AM   #7
Rewards Points: 502
The horizontal joints are easy to grind out because you just run the disc horizontally along each mortar line.
If you grind out the verticals, because of the speed of the cutter, and the short length of the joint (usually only about 2 1/2"), it is very easy to accidentally nick the top of the brick below and the bottom of the brick above. The wall will then look a mess.
For the verticals, try raking them out by hand with a chisel or old screwdriver.
The bit under the window is the cill. These can be built of brick (they slope to get the water away) but the vertical joints often break up because they are slightly more exposed to rain and frost than the joints in the main brickwork.
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
