Marble Grouting Question - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-22-2012, 08:02 PM   #1
Hello all,
I am new to this forum, so I hope I could hear from either a veteran or someone who has experience with this. I recently installed a carrara marble back splash. The tiles are 2" x 4" and they were glued to the meshing with a 3/8" space. My issue is, that I have read that unsanded grout should be used with polished marble so it won't get scratched, however, unsanded grout can not be used with grout lines greater than 1/8". So I don't know what to do in this situation, use unsanded so I don't risk scratching the tile but then it will crack later, or use sanded grout and scratch the brand new tile.
I also saw another Pre-mixed grout from HD called Simple Grout. This can be used with 3/8" grout lines and I don't believe it has sand. But this isn't real grout, so that is the downside there. Please help, I'm stuck!!
Thanks everyone!!!
kik240 is offline   Reply With Quote
Old 04-23-2012, 11:06 AM   #2
Just mix the sanded grout really loose. The sand in the grout is very fine and won't scratch the marble if you're gentle. I'd never use unsanded with a joint larger than 1/8".
I don't buy grout at HD, go to a reputable tile shop, they can put you onto the best sanded grout.
NickdaGreek is offline   Reply With Quote
Old 04-24-2012, 07:19 AM   #3
Rewards Points: 152
Agreed. Stay away from HD/Lowes if you have access to a tile shop. You might consider using a sealer on the tiles several times before grouting with the sanded.
TRUEPRO is offline   Reply With Quote
Tags
grout , marble , tile
Marble threshold question J187 Flooring 6 06-23-2009 09:14 PM
Noise, hollow, movement on cultured marble floor...need help? handfix2008 General DIY Discussions 8 11-04-2008 08:25 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
"grease pencil" on marble tiles! zel Flooring 7 04-29-2008 05:22 PM
