Loose Lag Shield Anchor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-17-2013, 08:21 PM   #1
Rewards Points: 4,796
Loose lag shield anchor
Let's say you have a gate door hanging on hinges which are directly threaded into lag shield anchors, which were inserted into holes in brick/mortar. The hole for the anchor was drilled with a 7/8" drill bit, which was the correct size for the anchor. But the anchor is now a little loose, probably because the door has been yanked on too hard. Can the hole be patched with fresh mortar, and the hole redrilled?
jeffnc is offline   Reply With Quote
Old 07-17-2013, 09:41 PM   #2
Rewards Points: 13,978
Of course you've tried tightening it?
I've used wooden wedges on the outside of the anchor.
Anchor setting epoxy will also work.
Old 07-17-2013, 10:37 PM   #3
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
No doubt that bit wandered a bit is why, could have hit a hard spot and was deflected to the side, could use wood like someone said, or maybe the next larger size anchor
Sculpture scholarship recipient, 2008
Asbestos information: http://www.diychatroom.com/f98/asbes...pt-1-a-181840/
RWolff is offline   Reply With Quote
Old 07-20-2013, 09:34 PM   #4
Next size anchor isn't an option, since the screw is integral with the door hinge.
Loose anchor bolts in Kenya juakali Building & Construction 7 03-27-2013 09:11 AM
Ice and Water Shield hansemx1 Roofing/Siding 19 11-07-2012 09:32 PM
Door frame resize conflicts with anchor bolt colossus610 Building & Construction 8 09-22-2012 10:28 AM
Ice and water shield SamReynolds Roofing/Siding 13 08-31-2010 02:03 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
