-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Loose lag shield anchor (http://www.diychatroom.com/f105/loose-lag-shield-anchor-183765/)
jeffnc 07-17-2013 08:21 PM
Let's say you have a gate door hanging on hinges which are directly threaded into lag shield anchors, which were inserted into holes in brick/mortar. The hole for the anchor was drilled with a 7/8" drill bit, which was the correct size for the anchor. But the anchor is now a little loose, probably because the door has been yanked on too hard. Can the hole be patched with fresh mortar, and the hole redrilled?
joecaption 07-17-2013 09:41 PM
Of course you've tried tightening it?
I've used wooden wedges on the outside of the anchor.
Anchor setting epoxy will also work.
RWolff 07-17-2013 10:37 PM
No doubt that bit wandered a bit is why, could have hit a hard spot and was deflected to the side, could use wood like someone said, or maybe the next larger size anchor
jeffnc 07-20-2013 09:34 PM
Next size anchor isn't an option, since the screw is integral with the door hinge.
