Loose Brick Veneer - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-01-2013, 10:19 PM   #1
Loose Brick Veneer
We are selling our house and the inspector found that one of the brick Veneer walls on the front of the Garage was loose. Its about a 4 foot tall but 3 foot wide section. It still looks and feels secure on the bottom, but can be moved out about 1/2 of a inch on the top. I really don't want to spend 500 bucks or so to get it secured or replaced. Is there any way to tighten that up to the wall of the garage?
All the brick peices look good and can take the sheet rock off the inside wall behind it if that info helps at all.
Thanks.
jeffreyLjohnson is offline   Reply With Quote
Old 08-01-2013, 10:46 PM   #2
Rewards Points: 13,300
Need a picture.
Old 08-01-2013, 11:05 PM   #3
Here is the best one I have for now. I will have to get a closeup of it tomorrow. You would never know there was anything wrong with it unless you pulled on it and I never really had a reason to pull on it.
It the Pic, its the left side Veneer.
http://flic.kr/p/eTcrTz
Old 08-02-2013, 05:28 PM   #4
Rewards Points: 1,232
Remove the sheetrock, screw wall ties to the mortar joint with tapcons and then nail them to the studs. You only need a couple.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Cutting a large hole in brick veneer wiz561 Building & Construction 4 09-09-2011 11:44 AM
another brick veneer problem question rdk4609 Building & Construction 6 06-12-2009 10:46 AM
Anchors & Brick Veneer rjordan392 Building & Construction 9 06-04-2009 05:58 AM
Removing a brick veneer Bayou Woman Building & Construction 6 06-02-2009 06:21 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
