Loose Brick On Fireplace Hearth - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-09-2013, 03:58 PM   #1
Rewards Points: 77
Loose brick on fireplace hearth
On my fireplace I have a loose corner brick, as shown removed in the picture attached. The mortar all remains in place when I remove the brick. Is there a good adhesive recommended to fix this? I see plenty of options such as a liquid nails 2 part epoxy or a one part adhesive. Will any of them work, as long as they mention masonry, or is one better than the other?
daveplot is offline   Reply With Quote
Old 11-09-2013, 06:17 PM   #2
Rewards Points: 13,300
No way would I be using any for of adhesive.
Remove the old mortar with a 4-1/2 right angle grinder with a diamond blade and a brick chisel.
Mist the area with water, remortar and put the brick back in place.
Old 11-09-2013, 08:20 PM   #3
joed's Avatar
Rewards Points: 12,028
Before you go removing the mortar you need to find a way to match the colour or it will look much worse than attempting to glue it.
Old 11-11-2013, 09:36 AM   #4
Rewards Points: 4,538
i'd use adhesive obviously just enough so it won't ' drool ' or be visible,,, small tube of silicone altho gorilla glue's good
Old 11-11-2013, 02:52 PM   #5
Concrete & Masonry
Rewards Points: 536
I agree with these two, it's far easier for a DIY'er to just glue it back in place than try to match the mortar again, especially when it's inside and will become a mess to use mortar........
jomama45 is online now   Reply With Quote
Old 11-12-2013, 08:16 PM   #6
Rewards Points: 77
that was a thought of mine, especially since a new vinyl plank was installed in that room today. This is the product I was thinking of: http://www.homedepot.com/p/t/100371817
Painting mortar on brick fireplace MsKitty32 Painting 13 02-08-2013 10:24 PM
Tile and wood over painted brick fireplace OddBuffalo Concrete, Stone & Masonry 0 08-17-2012 09:15 AM
Encasing a brick fireplace in wood Laborfree Carpentry 3 10-23-2011 08:40 PM
Suggestions on refacing brick fireplace Lynch Building & Construction 10 10-04-2011 08:33 AM
Brick Fireplace Paint ... g8master Building & Construction 3 12-20-2009 01:31 PM
