-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Loose brick on fireplace hearth (http://www.diychatroom.com/f105/loose-brick-fireplace-hearth-190036/)
daveplot 11-09-2013 03:58 PM
1 Attachment(s)
On my fireplace I have a loose corner brick, as shown removed in the picture attached. The mortar all remains in place when I remove the brick. Is there a good adhesive recommended to fix this? I see plenty of options such as a liquid nails 2 part epoxy or a one part adhesive. Will any of them work, as long as they mention masonry, or is one better than the other?
Attachment 77723
joecaption 11-09-2013 06:17 PM
No way would I be using any for of adhesive.
Remove the old mortar with a 4-1/2 right angle grinder with a diamond blade and a brick chisel.
Mist the area with water, remortar and put the brick back in place.
joed 11-09-2013 08:20 PM
Before you go removing the mortar you need to find a way to match the colour or it will look much worse than attempting to glue it.
stadry 11-11-2013 09:36 AM
i'd use adhesive :yes: obviously just enough so it won't ' drool ' or be visible,,, small tube of silicone altho gorilla glue's good :thumbsup:
jomama45 11-11-2013 02:52 PM
I agree with these two, it's far easier for a DIY'er to just glue it back in place than try to match the mortar again, especially when it's inside and will become a mess to use mortar........
daveplot 11-12-2013 08:16 PM
that was a thought of mine, especially since a new vinyl plank was installed in that room today. This is the product I was thinking of: http://www.homedepot.com/p/t/100371817
