Loose Brick - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-21-2012, 08:09 AM   #1
Loose Brick
While I was up on the ladder the other day, I noticed cracked mortar around one of my bricks. The brick in question is on the top course, and furthest to the left where it doesn't meet another brick since cedar shake shingle is accented on the gable it butts up against. The brick looks like it is tucked under the fascia board, but I can actually wiggle it like you would a semi-loose tooth. I suspect it started out as the weakest link in the bunch considering the fact that it only has mortar on two sides and its layed vertically. What can I do about it? I don't even know how the brick could be pulled out since it looks like an inch of it is tucked under the fascia. And then if the mortar is ground out and repaired, I doubt the new mortar will match the existing color and this is on the front of the house near eye level. The picture I attached is old and while the house was under construction because my camera is on the fritz today. I doubt the brick was loose back then. Any suggestions would be greatly appreciated!
segal is offline   Reply With Quote
My brick foundation has been parged... on the inside denvercraftsman Concrete, Stone & Masonry 2 08-27-2012 12:22 PM
Buying a house is this crack cause for concern? whodeydan General DIY Discussions 8 02-01-2012 01:46 PM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Reusing old brick for a shop bigalpha Building & Construction 12 01-20-2010 07:59 PM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 07:41 PM
