Liquid Binder For Tuckpointing Mortar Mix - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-23-2012, 01:19 PM   #1
Rewards Points: 1,062
Question
liquid binder for tuckpointing mortar mix
i am getting redo to do some old brick restoration for an exposed brick wall. since it is 100 y.o. brick, some local experts whom i forgot to ask this question advised against using the premixed home depot mortar and suggested i mix my own in the ratio 1 lime, 1 portland cement, and 6 sand.
however, i have also read somewhere something about a liquid binding agent and was wondering if perhaps that should be tossed into the mix for additional strength or smoothness.
thanks
Old 07-24-2012, 08:27 AM   #2
Rewards Points: 582
Check that the original mortar is not lime only mortar with no OPC. If so you would be better using a suitable lime mortar, especially if the bricks are soft ones.
stuart45 is offline   Reply With Quote
Old 07-24-2012, 07:56 PM   #3
Rewards Points: 152
Use type N mortar. No bonding agent. DONT use lowes/HD products. EVER. Case closed.
******Make sure the sand/mortar ratio is close as possible*******
For good measure, you never want the mortar too sandy. Too much sand makes the mortar weak and will wash away in 5 years instead of 50.
TRUEPRO is offline   Reply With Quote
Old 09-07-2013, 10:58 AM   #4
Rewards Points: 77
To the OP Amakarevic, now that I assume you have long completed this, what did you do, and what did you learn? I have a 100 yr old house in a climate that gets real winters, and am needing to repoint for winter. Curious about your outcome, and the inevitable "if I knew then, what I know now."
OurHouse is offline   Reply With Quote
Old 09-07-2013, 11:11 AM   #5
Rewards Points: 1,232
You need to check to make sure that you have or do not have lime mortar as a first step.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
OurHouse (09-07-2013)
Tags
tuckpointing
Replace mortar between stones in fireplace hearth support dm1337 Concrete, Stone & Masonry 3 06-17-2012 10:41 AM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 07:52 AM
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 07:44 AM
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 11:13 AM
mortar liquid bonding agent question drewhart Building & Construction 5 11-06-2008 07:45 PM
