Limestone Step Tread Repair - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-19-2014, 09:40 AM   #1
Rewards Points: 121
Hey folks!
I'm trying to not have to replace an entire limestone tread on the front steps and hoping that I can just repair it. There is a piece that has cracked off and is no longer attached to the brick stringer. Can I use construction adhesive for to reattach it to the stringer and then fill the crack with concrete patch or mortar? I'm not looking for perfection - rather just a quick fix to hold me over for a few years until I just redo the entire steps altogether.
What do you all think?
mikeyp78 is offline   Reply With Quote
Old 04-19-2014, 09:42 AM   #2
Rewards Points: 12,790
Got a picture?
mikeyp78 (04-19-2014)
Old 04-19-2014, 11:19 AM   #3
Rewards Points: 121
Yup.
Old 04-21-2014, 03:15 AM   #4
Rewards Points: 4,438
if you can live w/it fix'd it that way, fine by me saves removing the rail, replacing the tread, coring, & resetting the rail
irc
The Following User Says Thank You to stadry For This Useful Post:
mikeyp78 (04-21-2014)
Concrete step down to deck too short posull78 Building & Construction 6 03-03-2014 01:55 PM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
Repairing Broken Stair Tread RonnyK Carpentry 1 05-17-2006 02:37 PM
