Leak In Basement Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-18-2013, 06:44 PM   #1
Rewards Points: 160
Leak in basement wall
I guess I have something called a "dead mans wall" that has a leak on one of its side. The other side of it was already repaired with epoxy. What would be the best way to go about fixing this?
word2yamutha is offline   Reply With Quote
Old 03-18-2013, 07:02 PM   #2
Rewards Points: 6,652
You are going to have to dig down. If I had to take a wild guess, I would say your grade is wrong, along with no extenders on the downspouts, is why you are having that issue.
Old 03-18-2013, 09:43 PM   #3
Rewards Points: 160
I was told to dig down to the problematic area and apply paper tar. What exactly are extenders? What grade are you suppose to have? The weird part is it has only done that once. Every time I have been at the house to do repairs it never leaks even with its raining outside.
Old 03-18-2013, 10:38 PM   #4
concretemasonry's Avatar
Rewards Points: 2,566
Poured wall with corroded form ties rusting and leaking? The location of other ties (not corroded yet) are evident on walls in the photos.
Dick
concretemasonry is online now   Reply With Quote
Old 03-18-2013, 11:13 PM   #5
Your grade pitched towards the home, or has dropped, due to compaction, or run off, can cause this problem, with water going down the foundation, then finding the easiest leak, which you are seeing.
Downspout extenders are exactly that. They can be the flex adapters that you can get at Ace Hardware, Lowe's, Home Depot, or be a piece of downspout, or can be corrugated piping, such as what is used for French or perimeter drains, can also be used.
As for the tar paper, no you would not use that. You need to dig down, and when you do, use 4x8 sheets of 1/2" plywood, with 2x4's cut to brace the sheets, so that the dirt does not cave in while you are working on that section.
You remove as much of the old steel, then clean with a wire brush & TSP, let dry, then patch with Hydraulic Cement. After the cement dries, you can then apply the coating over it. You would be best to actually hire a crew, that would do the work, and then apply a membrane over the wall to further seal it from water penetration, and allow water to flow down to the Perimeter drain around the base of the foundation.
Old 03-19-2013, 06:03 PM   #6
Rewards Points: 4,442
poppycock,,, just excavate to the location of the leak ( already repaired, huh ? )... wire brush the dirt off the previously-completed repair & make sure the wall's dry,,, slather on some fiber-reinforced trowel-grade roofing ceement,,, for best protection, place a section of pond liner over it & slather the edges shut
dick's right - you'll probably have more to do in the future,,, once we get below 4', we need osha-approved shoring protection, trained ditchdiggers, & a competent person supervising,,, you can do whatever you want but, if i were you, tie a stout rope about your waist so anyone can easily locate your body
just 5 topics below: Need advice on Sealing exterior below grade wall
Frame out basement half wall diyinwi Remodeling 6 04-03-2012 10:08 PM
Properly supporting a basement wall under furnace ducting reblace Building & Construction 7 04-01-2012 09:26 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Small leak on bottom of basement wall? 5 Boroughs Building & Construction 5 07-02-2010 02:07 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
