Large Gap Between Retaining Wall And Driveway - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-17-2014, 12:53 PM   #1
Rewards Points: 14
Large gap between retaining wall and driveway
I have this retaining wall that seems to be giving way and the driveway slabs near it are subsiding. I can't say that it's gotten worse since I moved in in 2010, but I suspect it has gotten slightly worse.
The distance between the slab and the wall is probably 2-3 inches, but I haven't tried to figure out how deep it is. I think I'm afraid to know.
My thought is that the ultimate fix would be to rebuild the wall and mud jack the slabs. Because I think a roof might be highest on my priority list this ultimate fix might give way to a more temporary solution.
I'm also looking for a temporary solution that might add some waterproofness to my basement. This wall ties into the side of my garage (where it then also act as a wall to hold the fill below the garage slab). I think water may be entering here and then making its way to my basement that begins just past the garage slab. After really big rains I can get some seepage between at the base of my basement walls in that general vicinity of the garage. Unless there's an underground leak in the drains from the roof that I can't see, water from the driveway making it to this crack and then running back towards the house seems like the best culprit.
I just finished sealing areas of my house that had concrete slabs abutting the foundation by using backer rod and self leveling sealant. Would that be an appropriate solution here? It just seems like a lot of foam and sealant, even if I were to fill most of the void with sand or something first.
Thanks for any ideas.
Large gap between retaining wall and driveway-10390961_10153041867612565_5005778691831692872_n.jpg
life_aquatic is offline   Reply With Quote
Old 10-29-2015, 10:05 AM   #2
Rewards Points: 14
I hope it's not too soon to bump this post (it's been over a year).
Any thoughts on how to fill this gap and seal it.
thanks.
Old 10-29-2015, 08:43 PM   #3
Rewards Points: 240
i am not a pro. but if i didn't have any advice, like what you got. i would use hydrolic (sp?)
cement and fill that. build it up to be a slight curb.
Fix'n it is offline   Reply With Quote
Old 10-29-2015, 09:30 PM   #4
Rewards Points: 6,652
Personally I would just cut the sidewalk sections into six pieces, pull them out, then do a proper base, and do a Paver style walkway. It is the fact that it is old and most likely it has just sunk over age, or water has been washing under there when they put in that retaining wall, which really is more of a curb then a wall.
Old 10-30-2015, 03:10 PM   #5
Concrete & Masonry
Rewards Points: 636
Personally, I'd fill it with polymeric sand at this point of the year. Replace the concrete later as the budget allows..........
jomama45 is offline   Reply With Quote
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
The Big Dig! (redoing a retaining wall around my driveway) teamcampreder Project Showcase 71 08-23-2012 04:15 AM
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 09:03 PM
cracked driveway + leaning retaining wall = now what? agent425 Building & Construction 4 09-19-2010 02:51 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
