Landscaping Around New Colored Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-09-2012, 11:40 AM   #1
Hello. First post from me. I am in sunny, and hot, las vegas.
I had a patio poured with stamped colored concrete and had a couple questions.
1. I would like to start planting around it. How long until it is cured enough to start planting shrubs around it in 20" section between patio and house and patio and pool deck? Planting will involve getting concrete wet. Is 7 days enough time?
2. How long can I wash off the patio? How about scrub it with a non-metal brush (and light soap/water) to remove the dust and deisel fuel (release agent)? The release agent is keeping some areas very dark while others areas are very light and slightly dusty. Slab was poured 5 days ago.
3. Thoughts on using a light soap/water mix to wash the patio?
Thanks. This concrete stuff is complex stuff and a bit of an art.
12many is offline   Reply With Quote
Old 05-09-2012, 01:27 PM   #2
Too Short? Cut it Again!
Obviously if you have a stamped patio you had an artisan do it? Have you called and asked them these questions?
If it has been a week I hope it is on it way to being cured. It will change color as it does its thing.
The release agent was just applied to keep the stamp molds from sticking. I would rinse it off but not get paranoid about it hurting plants. I don't know what your folks used but most I have encountered is organic. You might want to do a quick Ph test (home kit will cost you $20) to see if you need to adjust for that.
I would not plant stuff until your done washing off your new patio too often and dragging hoses about. Since you are in Vegas? ODDS ARE you could drown or hurt them physically before whatever used for mold release will.
A pressure washer with low power nozzle might be better at getting the residual release agent off then your garden hose. Ask the installers though.
Old 05-09-2012, 02:28 PM   #3
Thanks. I appreciate your input.
Anyone else have any thoughts about whether the concrete is too green to work around with a shovel for planting?
Old 05-09-2012, 09:50 PM   #4
Concrete & Masonry
Rewards Points: 548
I can't speak for LV, but here, at 5 days old, it wouldn't be sealed yet, meaning it would be extremely vulnerable to staining.
If that's the case, this is my advice:
Don't walk on it, don't wash it off, don't touch it, and don't pay for it until it's sealed and you're happy with it.
jomama45 is offline   Reply With Quote
Old 05-10-2012, 11:02 AM   #5
Rewards Points: 3,520
Your patio won't be cured for 30 days,and where you live it's a very good idea to keep it wet to slow the drying process,thus avoiding the possibilites of stress cracking for at least a week,and possibly longer.
It would be to your advantage to wash off the diesel fuel,so the water can get to the concrete to keep it wet,and until your satisfied the diesel fuel is removed,i wouldn't put any plants in place,for detergent i would use Dawn to cut the oil,as it's been known to work better than other detergents for this purpose.
Canarywood1 is offline   Reply With Quote
Old 05-10-2012, 02:22 PM   #6
Concrete & Masonry
Rewards Points: 548
I missed the part about the diesel fuel.............
What happened to the contractor, did they die??????
I honestly wouldn't touch the concrete, it's the sole responsibility of the contractor to complete the job. I know I wouldn't want customers of mine dinking around with a stamped concrete job I was in the middle of..........
Old 05-10-2012, 03:58 PM   #7
The job is finished,but apparently the contractor used diesel fuel as a release agent for his stamping mats,instead of using a standard dry release agent cast on the surface, did it on the cheap i guess.
Old 05-10-2012, 07:11 PM   #8
Concrete & Masonry
Rewards Points: 548
How do you know it's complete from these two posts???
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Polished and Unpolished Concrete Floor Questions pretzels Flooring 5 03-05-2012 03:27 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
colored concrete slab and plaster--color combo help please! theriddler71 Interior Decorating 0 03-02-2010 04:15 PM
