King Size Brick Wall With Corners - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-10-2013, 10:29 PM   #1
King size brick wall with corners
Hello all, I am going to lay a small 2 wythes brick wall with 2 90 degree corners. Also would like to cap the wall with the same king sized bricks with a 1/4" overhang. Any pointers on the corner layout? I was planning to just do a running bond.
thanks
fb
fredbob is offline   Reply With Quote
Old 08-10-2013, 11:24 PM   #2
Rewards Points: 1,232
Standard running bond does not work with king size brick, you will have to do 1/3 bond or lay in some chips at the corners which do not look that good as a rule.
Edit- Modular brick are 4x8, so they work in bond around corners. Kings are not 5" wide, so they do not maintain bond around the corner. They are generally one third the length in width, which means if laid whole, they will be laid in 1/3 bond or you will have to have a small piece of brick (smaller than the desired minimum of 1/4 of a unit) to maintain running bond.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 08-11-2013, 01:23 PM   #3
Thanks for your reply. Looks like 1/3 bond is the way to go as bonding around the corner will require no cuts at all.
Old 08-11-2013, 02:04 PM   #4
Concrete & Masonry
Rewards Points: 548
The only way you're going to be able to use the same brick for the cap AND have an overhang is:
A) Have a cold joint running up each end jamb, which won't be as strong as a full brick tying the wythes together on the ends.......
B) Use two brick wide on the top (you'd have to cut/break all theses bricks, but you could then get more overhang as well) with a cold joint in the center of the cap.....
C) Somehow source the ever elusive "brick stretcher" that newb laborer's have been searching behind the seat of the truck for years for...........
jomama45 is offline   Reply With Quote
Old 08-11-2013, 03:24 PM   #5
It seems as though I could bring to outer wythe in (8" outside to outside) and use a whole brick as a cap with a small overhang. If I should be spacing the wythes a full brick I can skip the overhang...
Old 08-11-2013, 03:29 PM   #6
You can do it like that, but you should really flash under the cap. The corners of the cap should be 45'ed regardless.
Old 08-12-2013, 09:38 AM   #7
Rewards Points: 502
Agreed, though cutting those coping bricks at 45 so you don't see the holes will be tricky.
tony.g is offline   Reply With Quote
Old 08-29-2013, 01:20 PM   #8
Moving along
Thanks for the ideas. Looks like the 45's will work on the ends really good. Should I fill the cavity with reinforced concrete prior to capping?
Old 08-30-2013, 07:45 AM   #9
That will work, but it is not what I meant.
Old 08-31-2013, 05:21 PM   #10
Thanks. That is much better though mine won't be as perfect.....
jb
Old 08-31-2013, 11:01 PM   #11
Looks great to me.
Butting a wall aginst brick thistle3585 Concrete, Stone & Masonry 0 07-15-2013 10:40 AM
Brick Wall Fireplace Questions mjoe Remodeling 3 12-03-2012 07:40 AM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 02:45 PM
