Keyway In Top Of Footing? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-10-2013, 11:13 AM   #1
Rewards Points: 20
Keyway in top of footing?
I am about to begin forming footings for a foundation wall and I have found conflicting information online about the importance of a keyway in the top of the footing.
Some sources say it is an important feature to lock the stem wall into the footing and prevent lateral movement.
Others say it is unnecessary and even discouraged now days. The rebar and simple friction between the two pours will stop movement.
What's the deal?
Tubafore is offline   Reply With Quote
Old 08-10-2013, 12:32 PM   #2
Old School
Willie T's Avatar
Frankly, just think about it. Ever seen a block wall that was bumped by a truck? What immediately happens to the blocks that are "held in place by friction"?
Well, that is about all the connection your stem wall has to the footer. New concrete pours do not bond to old pours.
A running keyway is one of the simplest things to do. Why wouldn't you?
Willie T
Old 08-10-2013, 01:49 PM   #3
Rewards Points: 20
I agree a keyway makes sense and shouldn't be too difficult to form.
The talk I have found is that vertical rebar plus a roughened surface on top of the footing resists shear better than a keyway and makes it an unnecessary step. My engineer already spec'd #4 bar at 32" o.c. but made no mention of a keyway.
Old 08-10-2013, 01:57 PM   #4
Rewards Points: 1,232
It is also there as a waterproofing measure. Use something like a rubber waterstop poured into slab in the keyway or a product like Synko-flex instead.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 08-11-2013, 02:13 PM   #5
Concrete & Masonry
Rewards Points: 548
Depends greatly on what the foundation is for (full basement, garage with balanced fill on each side, crwal space, etc...) but with dowels on 32" centers, I don't think the keyway will do much at all. As a matter of fact, there's scenario's where a keyway in the footing will actually create more problems in a block foundation IMO...........
jomama45 is offline   Reply With Quote
Old 08-11-2013, 07:17 PM   #6
Registered User
Rewards Points: 5,466
IMO, the keyway is mute point. That is the purpose of the verticals tied to the horizontal footing rebar. Detached garage and addition says "or"; http://www.google.com/url?sa=t&rct=j...SLRngQ&cad=rja
Page 3; http://www.google.com/url?sa=t&rct=j...DDd_WQ&cad=rja
If basement living space, waterproof top of footing as said already or with membrane between, Fig.6, 9-14; http://www.buildingscience.com/docum...lation-systems Be sure at add a thermal break at slab/concrete wall as pictured, second biggest heat loss next to above grade areas.
Gary
Old 08-11-2013, 08:08 PM   #7
In the commercial work I have done the keyway was for waterproofing, not structural enhancement.
The Following 2 Users Say Thank You to Tscarborough For This Useful Post:
Gary in WA (08-15-2013)
Old 08-12-2013, 06:19 AM   #8
Rewards Points: 4,578
typically 1 finds a keyway more in commercial rather than residential,,, IF you promise ( no crissed finners behind your back, neither ) to properly waterproof the structure's foundation & bsmt walls, pass on the keyway,,, IF a schoolbus does hit the home, no keyway is going to save it
Old 08-12-2013, 11:22 AM   #9
Rewards Points: 20
Ok then, no keyway it is and I will properly waterproof. This will be a 36" tall crawlspace wall that will be partially backfilled.
I don't anticipate any schoolbuses crashing into it but just to be sure I will put up a sign in the yard forbidding it.
Old 08-12-2013, 05:32 PM   #10
GBrackins's Avatar
Rewards Points: 2,108
are you planning on leaving exposed soil in the crawl space or placing a concrete slab with vapor barrier?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-12-2013, 07:54 PM   #11
IF you leave soil rather than conc in the crawl space, use MINIMUM 15mm vapor barrier w/overlapp'd seams ( 12" ) secured by dble face tape,,, plan on 1st running it up the walls to your sill plate, too
The Following User Says Thank You to stadry For This Useful Post:
GBrackins (08-12-2013)
Old 08-13-2013, 08:57 AM   #12
Rewards Points: 20
No slab but I am going to use a vapor barrier over the soil and going up the sides.
Old 08-15-2013, 10:40 PM   #13
Registered User
IMO, leave the poly 2" down from the sill for annual termite inspection; http://termites101.org/termite-basic...ites-by-region
Gary
How to pour a replacement piece of footing? Homerepairguy Concrete, Stone & Masonry 2 02-29-2012 12:51 PM
Water supply line runs through footing site WillK Building & Construction 19 03-15-2011 01:39 PM
Footing drains in crawlspace on top of footing jbitt Building & Construction 8 01-12-2010 01:50 PM
Sinking footing tubes Farmer Z Building & Construction 19 11-17-2009 08:50 AM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 02:22 PM
