Just Wondering If My Foundation Has Issue - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-28-2014, 10:13 PM   #16
Rewards Points: 4,442
1/2 perf - see the holes in the top pic ? we coat fnd walls incl slab edge
Old 01-28-2014, 10:25 PM   #17
General Contractor
Gary Evans's Avatar
We can see just 1/2 the holes in the pipe.......the rest are facing the foundation
Gary Evans is offline   Reply With Quote
Old 01-29-2014, 08:59 AM   #18
1/2 perf'd - just can make out 1 row of holes in the top pic ? we coat fnd walls incl slab edge
i have a better monitor than jo 'cause he can't see any holes but not as good as gary's who can see holes that aren't there don't you guys have pvc pipe that's only perf'd on 1/2 of the surface ?
Old 01-29-2014, 09:42 AM   #19
Concrete & Masonry
Rewards Points: 470
I was mistaken, I went back a few times, and didn't see the perf holes until this morning........
From what I gather, the pipe is being used to drain water from the back yard to the front yard, or vice-versa, and it just happens to be next to the foundation. I wouldn't run the perf. next to the foundation, only at the end where it's actually collecting the water. I'd run solid bedded in less-impervious soils near the foundation IF it was me.............
But, I may not understand what the OP is trying to do here either.........
jomama45 is online now   Reply With Quote
Old 01-29-2014, 10:33 AM   #20
General Contractor
Gary Evans's Avatar
In most cases ( like this one ) it would help if the homeowner would back up and take a distance shot of the whole side of the building before taking close ups.
You can't take too many pictures when your trying to get help solving a problem with your home.
Those holes are really there itsreallyconcrete.........I wasn't seeing things.
right at the top of the pipe.
Waterproof Sill Plate, or Foundation, or French Drain? kgkg Concrete, Stone & Masonry 10 10-12-2013 01:32 AM
Concrete sidewalk against foundation - leaking zrooster99 Concrete, Stone & Masonry 5 06-06-2013 07:12 AM
How to stub off an old stone and mortar foundation beautah Concrete, Stone & Masonry 0 04-25-2012 10:43 AM
Foundation Issue... Fix? highspeedsentry Building & Construction 4 06-02-2011 12:02 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
