Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-24-2012, 05:39 PM   #1
iron rails broken
how to i mend the iron rails on the front steps
necther57 is offline   Reply With Quote
Old 04-24-2012, 05:49 PM   #2
iron rails broken
No picture, how would anyone know how to fix what we can not see.
Old 04-24-2012, 06:16 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
iron rails broken
Got to be wrought iron.
No other way but to weld them.
- Build Well -
Old 04-24-2012, 06:52 PM   #4
Ravenworks's Avatar
iron rails broken
There is another way to fix them if it is broken at the anchor, you get some box tubing and weld a dowel into each end and epoxy the dowel into the concrete,then slide the dowel into the existing post then weld the two together.
Ravenworks is offline   Reply With Quote
Old 04-24-2012, 08:45 PM   #5
iron rails broken
Originally Posted by Ravenworks View Post
There is another way to fix them ........ then weld the two together.
Huh?
UM....that still involves "Welding".
= The average Home Owner does not possess welding equipment, nor welding knowledge and skills - to perform a DIY repair.
Although - its a "real good excuse" to start the whole welding equipment purchase process. Also, there are some good tutorials on You-thingy.
- Build Well -
Old 04-24-2012, 09:17 PM   #6
Ravenworks's Avatar
iron rails broken
Huh?
I was referring to another fix reguarding welding the tube to dowels sorry
I ran into this and didn't have the time to make the parts up,I had a fab shop make the piece up, it was $15 and a phone call
I cut out the rotten section to match height of new bow tubing,inserted the dowels into both holes and epoxy both insertion points.
It's a nice work around since you can never get the old stanchions out,which leaves the other problem of dealing with the old anchor points
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 11:39 AM
Remove Rust from Cast Iron Bed Rails cpalmer67 General Discussion 8 07-24-2009 03:25 PM
iron vent pipe broken at fitting CCarlson Plumbing 3 02-18-2009 08:40 PM
Cast iron pipe broken? tervic Plumbing 6 02-18-2009 07:23 PM
Wooden Top For Wroght Iron Railings ThomF Carpentry 10 11-01-2007 12:41 PM
