Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-07-2013, 02:05 PM   #1
Iron railing came out of cement wall
I live in a town house, the outer walls are cement for fire purposes. I own the house and the railing that leads down stairs was pulled directly out of the cement fire wall. What would be the best way to repair this so the railing can be reinstalled?
Kidcarlyle is offline   Reply With Quote
Old 01-07-2013, 03:42 PM   #2
So I have been scanning the site and looking for something similar, I found that there is Quikrete anchorning that can be used on railings. However from what I read this seems to be used primarly when mounting to outside cencerete stairs and would be from the ground up, since I have to mount this from the wall out this does not sound like the method.
I also located information on concrete expansion anchors, what I wondering is one from the looks of the hole, which is two clean holes about the size of a quarter. The expansion anchros look to be smaller then the hole itself, I am sure there are larger if this is the right tool for the job. However the hole for the screw that attaches the raling to the wall is smaller then the exansion anchors. Is there a way to attach the railing to the anchors, drill out the hole on the railing mount? Is there another way to do this? Would I be better off patching the concerete and starting fresh? Any help would be great.
Old 01-07-2013, 03:53 PM   #3
You're on the right track. Expansion bolts or anchoring epoxy. Both are viable options. You may be able to drill out the holes in the handrail's mount. Pictures would help us help you.
Seattle2k is offline   Reply With Quote
Old 01-07-2013, 07:47 PM   #4
most townhouse communities reserve exterior repairs to the hoa - your bldg MAY be stucco over conventional wood framing in which instance it would be advantageous knowig to what you anchor,,, $.25 size holes sound as if lead anchors were originally employed suggesting masonary backup.
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 01-07-2013, 08:26 PM   #5
Ok I took some picture of the situation at hand hopefully that will clear up some of the questions. As far as HOA no worries there, this is inside the house and there is no HOA for my town house.
I am going to have to do this in two posts, as it will only allow 5 pictures.
Photo 1 - 3 - hole in cement wall with measure
Photo 4 - 5 - screw that was previously used for mounting
Photo 6 - previous mounting hardware
Iron railing came out of cement wall-photo.jpg   Iron railing came out of cement wall-photo-2-.jpg   Iron railing came out of cement wall-photo-3-.jpg   Iron railing came out of cement wall-photo-4-.jpg   Iron railing came out of cement wall-photo-5-.jpg
Old 01-07-2013, 08:29 PM   #6
photo 7 - mounting hardware
So this is what was previously used to mount the railing to the cement wall; the issue now is the the old hardware can easily slide in and out of the hole that is in the wall. Would using a cement anchor be the right call in this situation? Will I have to patch the wall? Again any recommendations would be a great help.
Thanks!
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 07:17 AM
Oak hand rail on existing iron stair railing SHREDTHESYSTEM Carpentry 9 03-22-2010 06:30 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 11:11 AM
