Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-31-2012, 08:45 PM   #16
Super Moderator
Interlocking pavers mold
I know I'm a super moderator--but I am a failure with computers--I admit that I can not post pictures--
So--no pictures,sorry
oh'mike is online now   Reply With Quote
Old 06-01-2012, 08:05 AM   #17
No problem. Attached is my current driveway it is in good condition except where the root from a tree lifted it by the garage door. My goal is to make it wide enough for a car coming out of the hate to get around a car in the driveway. I'll be renting a jack hammer to bust up the driveway, walkway, and patio this weekend.
ryanb4614 is offline   Reply With Quote
Old 06-01-2012, 08:05 AM   #18
Old 06-01-2012, 07:13 PM   #19
As you can see water runs right into the garage for how it's raised.
Old 06-01-2012, 08:10 PM   #20
Ravenworks's Avatar
Saw cut that section out and replace it and paver brick a turn around?
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Old 06-02-2012, 08:51 AM   #21
When I priced pavers vs concrete for a driveway replacement the concrete was, on average, a little over half the cost of the pavers.
Don't know what the difference would be in your area but it might be worthwhile to check. A DIY concrete solution might be affordable.
7echo is offline   Reply With Quote
Old 06-02-2012, 08:14 PM   #22
I second 7ECHO. I had a tentative, rough estimate for pavers in the last two months and was almost three times the cost of concrete, all labor included.
rdy2go is offline   Reply With Quote
Old 06-02-2012, 08:19 PM   #23
I think we will be getting pavers and doing it ourselves. Driveway is 30 feet and currently 10 ft wide. Going to break out all concrete and do all pavers extending it to 16-18 ft wide
Old 06-02-2012, 09:50 PM   #24
concretemasonry's Avatar
ryan -
Probably a good chice for your situation.
Real interlocking concrete pavers can be a very good DIY solution, since it can be done at your pace. Just make sure to throw a coating if fine sand on the top and use a plate vibrator to finish up, true the surface and create the high pavement strength necessary for the application.
Dick
concretemasonry is offline   Reply With Quote
Mold found - unsure what to do?? izzyant88 General Discussion 12 06-17-2011 07:21 AM
Interlocking pavers around pool ladygodiva3 Landscaping & Lawn Care 3 04-14-2010 07:20 PM
Question regarding interlocking pavers Ndavidson Flooring 1 08-26-2009 08:47 PM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 07:56 AM
Interlocking pavers & stair leading to house amdspitfire Landscaping & Lawn Care 6 07-21-2008 04:30 PM
