Interior Stone Veneer The Right Way - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-28-2012, 11:12 PM   #1
Rewards Points: 150
Interior stone veneer the right way
I am (for the first time) installing a fireplace and would like to dress it out using a stone veneer. The fireplace guy told me to cover the framing with Durock and mortar the veneer to that. When I mentioned lath and scratch coats, he indicated that wasn't necessary.
Which is why I am posting this - I'm not convinced that it wouldn't be a good use of my time to do either or both.
I am considering a dry stack look (i.e. no grout lines).
Could someone spell out the method and materials I should use to minimize potential headaches?
zakany is offline   Reply With Quote
Old 11-28-2012, 11:42 PM   #2
Rewards Points: 1,232
Consult the manufacturers installation instructions, but he is right, other than I prefer to use thinset over cement board. If you use thinset, you may have to knock off some of the high points on the backside of the fake stone.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-29-2012, 09:40 AM   #3
Rewards Points: 150
So if I install Durock rough side out, that it will be rough enough to, essentially, act like a scratch coat?
You also mentioned the use of thinset rather than, say, type S mortar. Thinset I have. Do you suggest a modified or unmodified thinset?
I understand that I would butter the back of the stones, leaving a divot in the center to help suction the veneer to the wall.
I a wet saw a good way to cut this stuff?
Old 11-29-2012, 10:02 AM   #4
Personally, I prefer hardibacker, but either will work. Modified thinset, buttered as stated, although most manufacturers will recommend 100% buttering.
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 06:30 PM
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 07:39 PM
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 05:57 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 05:03 PM
