Interior Stone Ledger On Framed Wall - Epoxy. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-01-2013, 02:51 PM   #1
CreativeGuy's Avatar
Interior stone ledger on framed wall - epoxy.
Hi, I have some beautiful dry stack ledger stone panels (6" X 24") that I would like to put up on an interior wood framed wall. It will be about six feet tall and twelve wide. Is there a way to use some sort of adhesive i can use? Or do I need to go the whole, plywood > tar paper > metal lath > scratch coat > thinset mortar, route?
I have 2X6 wall framing up but nothing else yet.
Steve
http://dragonflyhill.org/
CreativeGuy is offline   Reply With Quote
Old 09-01-2013, 07:31 PM   #2
DIY staff
Rewards Points: 7,174
Welcome ----your questions will be answered right here---no need for your E-mail----
Typically thinset mortar is used--wall is covered with 1/2" Durrock--
However---I'm not a mason---when one shows up--listen to them---Mike--
Old 09-01-2013, 07:35 PM   #3
DIY staff
Dragonfly Hill | Building an Earth Sheltered Home
OOPS----Sorry---This is a link to a blog---not an E-mail---
Looks interesting,too.----Mike--------
Old 09-02-2013, 12:40 AM   #4
Rewards Points: 1,230
1/4" Hardi-backer screwed to the studs over sheetrock or 1/2" hardi-backer over the studs is the minimum, and don't be shy with the screws. Thinset the stone to the Hardi-backer and you are fine.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 09-02-2013, 11:09 AM   #5
I should also mention that my stud spacing is 24" OC.
Does anyone have an opinion on using Schluter Systems Kerdi Booard instead of cement board? I have used this for tile and found it great to work with.
Old 09-02-2013, 11:46 AM   #6
You should have the studs 16" o.c. or you are on unknown ground. The stone weighs 14# per SqFt +/-, FYI.
Creating doorways/supporting wall issues NWVintage Remodeling 2 12-19-2012 04:19 PM
What is the best way to hang a heavy antique wood framed mirror to a glass wall jimmcfarlane Building & Construction 3 10-11-2012 08:06 AM
wall below low deck ledger amakarevic Building & Construction 3 02-24-2011 09:22 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
