Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-23-2013, 07:40 PM   #1
insulating basement foundation walls
thanks for any help, can i use closed cell spray foam as a water barrier to seal foundation walls that get damp before i sheetrock
mvl 2618 is offline   Reply With Quote
Old 02-23-2013, 07:44 PM   #2
Nope, need to address why there getting most before doing anything.
Proper grade outside, working gutters, no mulch piled up againt the foundation.
May need a french drain.
Ever check the humity in the basement?
May also need a dehumidifier.
Old 02-23-2013, 07:50 PM   #3
i have dehumidifier working outside yard holds lots of water just gets damp wanted to fix from inside instead of digging
Old 02-23-2013, 07:51 PM   #4
new to forum thanks for response
Old 02-25-2013, 10:47 AM   #5
"You can do anything"-Mom
brockmiera's Avatar
Post a picture of the outside of the house. Usually there are easy fixes that can be done outside before you have to resort to digging and waterproofing.
Without seeing what you are seeing it will be impossible to help.
Doing any finish on the inside will be throwing away money if you dont address and fix the cause of the issues.
brockmiera is offline   Reply With Quote
Old 02-25-2013, 11:55 AM   #6
concretemasonry's Avatar
Often, true interior french drains (not cute little collection trenches or stick on plastic systems) placed at the bottom of the footings will remove moisture under the slab and around the foundation walls since water flows horizontally and vertically over time.
In many cases, they are easier and faster to install and can be cheaper than tearing out landscaping, slabs, etc. for a real exterior french drain.
This is a long term option to get rid of the wet soil around the house and decrease the hydrostatic pressure on the walls and floors that causes the leakage. The reason it is a long term situation is that the moisture is removed continuously every day and the soil can absorb moisture from a several day event before any leakage shows up.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Gary in WA (02-25-2013)
Insulate rim joist & basement walls- if exterior walls have no insulation? cbrc5eric Insulation 5 02-01-2012 08:47 AM
100 year old foundation. 2 walls deteriorating. strategery Building & Construction 1 08-10-2011 02:03 PM
Insulating basement - questions jtmann HVAC 7 11-19-2010 04:20 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
