-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   insulating basement foundation walls (http://www.diychatroom.com/f105/insulating-basement-foundation-walls-172756/)
mvl 2618 02-23-2013 06:40 PM
thanks for any help, can i use closed cell spray foam as a water barrier to seal foundation walls that get damp before i sheetrock
joecaption 02-23-2013 06:44 PM
Nope, need to address why there getting most before doing anything.
Proper grade outside, working gutters, no mulch piled up againt the foundation.
May need a french drain.
Ever check the humity in the basement?
May also need a dehumidifier.
mvl 2618 02-23-2013 06:50 PM
thanks joe
i have dehumidifier working outside yard holds lots of water just gets damp wanted to fix from inside instead of digging
mvl 2618 02-23-2013 06:51 PM
new to forum thanks for response
brockmiera 02-25-2013 09:47 AM
Post a picture of the outside of the house. Usually there are easy fixes that can be done outside before you have to resort to digging and waterproofing.
Without seeing what you are seeing it will be impossible to help.
Doing any finish on the inside will be throwing away money if you dont address and fix the cause of the issues.
concretemasonry 02-25-2013 10:55 AM
Often, true interior french drains (not cute little collection trenches or stick on plastic systems) placed at the bottom of the footings will remove moisture under the slab and around the foundation walls since water flows horizontally and vertically over time.
In many cases, they are easier and faster to install and can be cheaper than tearing out landscaping, slabs, etc. for a real exterior french drain.
This is a long term option to get rid of the wet soil around the house and decrease the hydrostatic pressure on the walls and floors that causes the leakage. The reason it is a long term situation is that the moisture is removed continuously every day and the soil can absorb moisture from a several day event before any leakage shows up.
Dick
