Insulate Basement Knee Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 09-06-2013, 03:33 AM   #1
Angry
My basement has a short cinder block wall that is interior and on the other side is a sloping crawlspace away from my basement. I found the best video that solved my problem. How to insulate the wall.
http://m.youtube.com/watchv=iRXnHRsA...ure%3Dyoutu.be
Just do not understand why the guy has to lay a top blue insulation board on top his pony wall then have another one go under the pony wall onto his concrete?
Just wondering if I need to frame in my pony wall or knee wall?
I want to place the Owens insulation tight up against the cinder block wall and partial 3 foot knee wall. Next lay treated wood on floor then steel frame on top of treated wood tight to Owning 2" insulation. Finally sheet rock.
RachWashState is offline   Reply With Quote
Old 09-15-2013, 10:15 PM   #2
Registered User
Rewards Points: 526
Are you East or West of the mountains? Closest large city?
Gary
Old 09-17-2013, 03:17 AM   #3
Portland Oregon.
Old 09-18-2013, 04:29 PM   #4
Registered User
Rewards Points: 526
Fig. 1 and 2 is the best way to insulate the basement wall. Air-tight coverage; 1' square grid of foam compatible adhesive on backside of f.b., canned foam or caulk around perimeter of rim f.b. If you use the "search" white box at top of every page, many posts will list the proper way.
Coastal side of mountains requires R-2.5 to prevent condensation in cavity; http://www.buildingscience.com/docum...r-requirements
You would need that thickness XPS to prevent condensation and R-13 (f.g.) in the wall to meet your energy code requirements OR just R-10 (2"XPS) as listed without a frame wall/cavity F.G. insulation. Need to run wires?
Gary
PS. the video wouldn't play for me. Foamboard under the frame wall is a thermal/air/capillary break; http://www.greenbuildingadvisor.com/...-building-code
Old 09-20-2013, 11:40 AM   #5
Gary, thank you!
Fig 1 and 2? Would like to see.
The video is Basement walls by Todd Fratzel, but not to sure what he has on the other side of his wall.
Mine is in interior wall with crawlspace on the other side. Crawlspace slopes to the other wall.
Old 09-20-2013, 07:48 PM   #6
Registered User
Rewards Points: 526
I am so sorry, I forgot the link; http://www.buildingscience.com/docum...ce-insulation/
Fb requires gluing for an air barrier against basement air condensing on the cold concrete wall; The wall assembly must prevent any significant volume of
interior air from reaching the cool foundation wall. Thus it
must have an effective interior air barrier or a method of
elevating the temperature of potential condensing surfaces
(such as rigid insulation installed directly on the interior of
concrete or masonry surfaces). From; http://www.buildingscience.com/docum...lation-systems
And; http://joneakes.com/jons-fixit-database/743
If still interested and need further proof, lol; "Roads to failure" and "Air movement"; https://docs.google.com/viewer?a=v&q...qqQTqzkXnRJfcQ
ADA; http://www.buildingscience.com/docum...wall-approach/
Gary
PS. the above-grade portion of crawl-space interior wall needs insulation, if outside vented. Add a weatherproof door between the two.
Old 09-24-2013, 02:48 AM   #7
Thank you!
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Framing basement exterior walls gheffron Building & Construction 7 06-08-2012 01:00 AM
Basement Finishing - 'knee wall' ledge JeffreyMCooper Carpentry 4 07-11-2011 03:26 PM
how to insulate and build exterior basement wall brentschultz Building & Construction 3 02-03-2011 11:09 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 08:39 AM
