-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Insulate Basement Knee Wall (http://www.diychatroom.com/f105/insulate-basement-knee-wall-186577/)
RachWashState 09-06-2013 04:33 AM
My basement has a short cinder block wall that is interior and on the other side is a sloping crawlspace away from my basement. I found the best video that solved my problem. How to insulate the wall.
http://m.youtube.com/watchv=iRXnHRsA...ure%3Dyoutu.be
Just do not understand why the guy has to lay a top blue insulation board on top his pony wall then have another one go under the pony wall onto his concrete?
Just wondering if I need to frame in my pony wall or knee wall?
I want to place the Owens insulation tight up against the cinder block wall and partial 3 foot knee wall. Next lay treated wood on floor then steel frame on top of treated wood tight to Owning 2" insulation. Finally sheet rock.
Gary in WA 09-15-2013 11:15 PM
Are you East or West of the mountains? Closest large city?
Gary
RachWashState 09-17-2013 04:17 AM
Portland Oregon.
Gary in WA 09-18-2013 05:29 PM
Fig. 1 and 2 is the best way to insulate the basement wall. Air-tight coverage; 1' square grid of foam compatible adhesive on backside of f.b., canned foam or caulk around perimeter of rim f.b. If you use the "search" white box at top of every page, many posts will list the proper way.
Coastal side of mountains requires R-2.5 to prevent condensation in cavity; http://www.buildingscience.com/docum...r-requirements
You would need that thickness XPS to prevent condensation and R-13 (f.g.) in the wall to meet your energy code requirements OR just R-10 (2"XPS) as listed without a frame wall/cavity F.G. insulation. Need to run wires?
Gary
PS. the video wouldn't play for me. Foamboard under the frame wall is a thermal/air/capillary break; http://www.greenbuildingadvisor.com/...-building-code
RachWashState 09-20-2013 12:40 PM
Gary, thank you!
Fig 1 and 2? Would like to see.
The video is Basement walls by Todd Fratzel, but not to sure what he has on the other side of his wall.
Mine is in interior wall with crawlspace on the other side. Crawlspace slopes to the other wall.
Gary in WA 09-20-2013 08:48 PM
I am so sorry, I forgot the link; http://www.buildingscience.com/docum...ce-insulation/
Fb requires gluing for an air barrier against basement air condensing on the cold concrete wall; The wall assembly must prevent any significant volume of
interior air from reaching the cool foundation wall. Thus it
must have an effective interior air barrier or a method of
elevating the temperature of potential condensing surfaces
(such as rigid insulation installed directly on the interior of
concrete or masonry surfaces). From; http://www.buildingscience.com/docum...lation-systems
And; http://joneakes.com/jons-fixit-database/743
If still interested and need further proof, lol; "Roads to failure" and "Air movement"; https://docs.google.com/viewer?a=v&q...qqQTqzkXnRJfcQ
ADA; http://www.buildingscience.com/docum...wall-approach/
Gary
PS. the above-grade portion of crawl-space interior wall needs insulation, if outside vented. Add a weatherproof door between the two.
RachWashState 09-24-2013 03:48 AM
Thank you!
