Install Gas In A House - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-07-2013, 08:14 PM   #1
Install gas in a house
I want to install to gas lines into a house that has a concrete slab foundation. Can it be installed above the concrete slab?
Stevepray is offline   Reply With Quote
Old 03-08-2013, 02:10 AM   #2
Rewards Points: 13,472
#1 No DIY should be running there own gas lines!
Old 03-08-2013, 01:06 PM   #3
Rewards Points: 4,586
ours enters above the slab,,, matter of fact, the meter/reducing valve's about 5' above the slab,,, w/the right mtls, plumbing for gas is just like water 'cept, if you have a leak, water don't burn up your house be safe & call a pro - then, if something goes ape****, you gots someone to sue
Looking for help on how to install recessed soffit. Snoopy_ Roofing/Siding 2 09-04-2012 03:45 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Install undersink filter or whole house!? Mike2181 Plumbing 7 07-19-2010 10:14 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
