#1 |
i'm about to cover up this pvc pipe in my basement
hi...
i'm about to cover up my pvc waste pipe with concrete in my basement and wanted to check with the experts here to make sure i'm doing it right... i've never done this before so your comments/criticism/jokes are welcome... - start back filling with dirt to top of pipe - add gravel - add that quickrete stuff from home depot (following their directions, of course) is it possible to just go right to the quickrete without the dirt and/or gravel? also, i'm planning on putting in a bathroom in the basement in a few years... should i take steps to prep for that now or just dig it up again then? thanks.
#2 |
Super Moderator
You need to bed that on gravel-----and Yes---get the plumbing rough done for the future basement now.
It appears that there is no floor now---
New members: Adding your location to your profile helps in many ways.--M-- |
#3 | |
i'm about to cover up this pvc pipe in my basementQuote:
Do you need the practice busting up concrete/digging? Do you not have the money now to do the rough in? To each his own. |
#4 |
- Do all rough-in now, forget digging up the floor in a few years, total nonsense
- Verify your Muni allows PVC in-ground, some do, some don't - Install a gravel bed under and around the PVC pipe completely, lay a membrane over the PVC prior to pouring cement so cement doesn't make direct contact - make sure the pipe has proper slope |
#5 |
thanks for all the replies...
will try to cover up that area with some plywood... will that pass a Temp CO inspection? i'm definitely gonna try to do the rough-in if i can find the time... i've got a thousand other things to take care of for this inspection... |
#6 |
That pipe needs to be deeper! Seriously if you pour over that it will only be what 2" under the concrete? That is to close! It could freeze or get nailed into when you frame.
| Display Modes | |
| Weird pipe in basement floor - Water on floor | nserafini | Plumbing | 10 | 08-20-2012 07:19 PM |
| Leaking around old drain pipe in basement | spg | Plumbing | 1 | 08-16-2011 12:27 PM |
| Basement drain pipe "pit" ground water fix. | alecmcmahon | General Discussion | 13 | 12-01-2010 06:42 AM |
| Basement Decorative Wood Wall Cover popping up | tk3000 | Building & Construction | 8 | 10-29-2010 01:17 PM |
| Framing basement wall with drain pipe | owais | Remodeling | 13 | 03-25-2009 10:48 AM |
