Ideas On How To Repair The Brick That Was Broken For The Pipes - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-29-2013, 08:56 PM   #1
Ideas on how to repair the brick that was broken for the pipes
I was planning on taking off the plaster to put up drywall and insulation. But after removing the plaster where the sink was, this is what i found. I was wondering what should I do to fill in the void space between the bricks?
Ideas on how to repair the brick that was broken for the pipes-house-photo.jpg
garrisj1 is offline   Reply With Quote
Old 12-29-2013, 08:59 PM   #2
Rewards Points: 582
was you planning on replacing that plumbing .....????? ben sr
Old 12-29-2013, 09:18 PM   #3
Yes I was planning on doing that as well
Old 12-29-2013, 09:27 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
Thread moved
Old 12-29-2013, 10:51 PM   #5
Msradell's Avatar
Rewards Points: 126
You obviously are not going to need anything for additional structural support since it's been that way for so long. Your best bet in probably the easiest way to do anything would be to fill the void with expandable foam (a couple of cans would probably do it) after you install the new piping. You could then trimmed out any excess before installing the new sheetrock. Are you going to stud out the wall to add insulation?
Msradell is offline   Reply With Quote
Old 01-01-2014, 01:03 PM   #6
I was going to stud it out to put up insulation and to run new electrical lines.
Old 01-01-2014, 02:28 PM   #7
Rewards Points: 6,652
Take a sample of the Mortar that is in the walls now, to your local Cement yard. They should have a lab, that they can tell you the makeup that was used, so you can get a mix made for patching those sections that need to be.
As for the piping, I would just pack some Fiberglass or Roxwool around where you can, to stop drafts, then use two layers of Gypsum on the wall, with Green Glue between the layers.
Looks like an old Factory home, that one of the local Steel factories built for their workers, or Post-War. Any pictures of the outside and other areas like the Bath & Laundry, that you have, that you are running into the same issue.
Old 01-01-2014, 03:24 PM   #8
Concrete & Masonry
Rewards Points: 530
What are you talking about???
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
kwikfishron (01-02-2014)
Old 01-01-2014, 03:29 PM   #9
Looks like you just jumped in with no clue of the discussion. Jomama45, maybe read the whole thread, before jumping on someone for what they posted.
Old 01-01-2014, 03:50 PM   #10
Concrete & Masonry
Rewards Points: 530
No, I read it all before posting Greg. Your advice still makes no sense to me. Sometimes I wonder where you get this stuff from............
djlandkpl (01-02-2014)
Old 01-01-2014, 04:07 PM   #11
I just started in the kitchen right now. Its a 1.5 story house built around 1900. I think the first floor exterior walls are all plaster over brick.
Old 01-01-2014, 04:15 PM   #12
I was wondering about the age, due to the type of construction of the walls.
Old 01-02-2014, 04:40 AM   #13
Rewards Points: 4,534
if 1 one responder thinks there might be some historical significance, you might consider a web-cam & subscription svce me ? i'd stuff it w/f-g & rock over it
Old 01-02-2014, 03:03 PM   #14
Rewards Points: 582
They look a bit like terracotta blocks on the inside skin.
You could also use some deep frogged bricks like these with the frogs cut down to make them thinner, and lay them on edge.
stuart45 is offline   Reply With Quote
The Following User Says Thank You to stuart45 For This Useful Post:
gregzoll (01-02-2014)
Concrete on Brick Step Repair averyjohn Concrete, Stone & Masonry 2 07-09-2013 07:23 PM
broken sewer pipes with belly chatty Plumbing 1 07-30-2010 10:31 PM
repair of broken dwv line from kitchen to the main. docwatson Plumbing 8 05-06-2009 12:14 PM
How do I repair a broken towel rack that was attached to the tile? meganprncss General DIY Discussions 2 05-03-2009 10:40 AM
OK, no patio fro the broken Granite and Marble any ideas? BJLower Tiling, ceramics, marble 2 02-02-2009 07:57 AM
