I Want To Remove An Old, Unused Chimney - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-05-2012, 12:40 PM   #1
Rewards Points: 156
I want to remove an old, unused chimney
It's a red brick chimney close to the center of the house. I have a high efficiency furnace directly vented to the outside with PVC pipe. I have an electric water heater.
I would have some drywall work to do for the ceiling and wall as well as something to fill the void in the floor until I replace the floor.
Is this just a straight-forward deal where I go up in the attic myself and start knocking bricks out one by one with a chisel and hammer? Is there anything I should try to do to prevent soot from getting everywhere?
strategery is offline   Reply With Quote
Old 06-05-2012, 07:31 PM   #2
Rewards Points: 240
what pitch is the roof ? pics ?
Fix'n it is offline   Reply With Quote
Old 06-05-2012, 08:13 PM   #3
DIY staff
Rewards Points: 7,174
You need to start on the roof--=and just like you mentioned---chisel and hammer--
Patch roof--then the attic---
on down to the basement---
Sell or give away the brick--Craigs list would be a good choice--
The toting bricks out of the house is the hard part--
strategery (06-05-2012)
Old 06-05-2012, 11:59 PM   #4
Rewards Points: 156
I am going to have my roof replaced soon. I think this is the ideal opportunity.
Is it likely that the chimney provides structural support? It's an old house.
Old 06-06-2012, 05:13 AM   #5
DIY staff
How old?
If you find floor joists let into pockets in the brick--then it is suppurating the structure--
That seldom was done after 1880--
Old 06-06-2012, 05:54 AM   #6
Rewards Points: 156
1919. The only thing I notice is that the main floor beam in the basement is fastened to it. I was planning to replace that beam with a new seamless steel beam.
Old 06-06-2012, 06:30 AM   #7
DIY staff
Do post pictures of you can--I would at least remove the section sticking out of the roof--and the part in the attic--
If a chimney is deteriorating and not needed--remove the offending thing and roof over the opening.
Old 06-06-2012, 12:55 PM   #8
Rewards Points: 156
It actually doesn't stick out of the roof. In order to get a picture of it, I have to go up in the attic.
I think I should take a picture of it from the basement. I will update this post later when I can get some pictures.
The Following User Says Thank You to strategery For This Useful Post:
oh'mike (06-06-2012)
Old 04-04-2013, 01:22 AM   #9
Rewards Points: 156
Just wanted to provide an update. I was able to completely remove the chimney!
I want to remove an old, unused chimney-img_0195.jpg   I want to remove an old, unused chimney-img_0200.jpg   I want to remove an old, unused chimney-img_0201.jpg   I want to remove an old, unused chimney-img_0208.jpg   I want to remove an old, unused chimney-img_0209.jpg
Old 04-04-2013, 01:28 AM   #10
Rewards Points: 156
Just a bunch of the photos I took from all of the stages of the process. It went through the master bedroom closet which I intend to redo. Going to put up new drywall, cut out the floor and put in new floor and trim and new closet hardware.
It's a lot of work, but I think it will be worth it. Some of the work I have to hire out. I'm able to do all of the demo myself.
I want to remove an old, unused chimney-img_0212.jpg   I want to remove an old, unused chimney-img_0228.jpg
The Following 2 Users Say Thank You to strategery For This Useful Post:
oh'mike (04-04-2013)
Old 04-04-2013, 05:29 AM   #11
DIY staff
Thanks for the update------you did a good thing----Mike----
Old 04-04-2013, 10:44 AM   #12
Rewards Points: 3,842
That liner didn't look to be that old.
Canarywood1 is online now   Reply With Quote
Old 04-04-2013, 12:41 PM   #13
Rewards Points: 156
I think it exhausted the last furnace's or water Heater's combustion air. I think the old furnace was about 15 years old and the water heater was about the same.
Before the last reroof, they demolished the chimney below the roof which made my job a lot easier.
Old 04-04-2013, 08:24 PM   #14
Rewards Points: 240
i have the same type of chimney that needs to come down, mine goes through the roof.
Old 04-07-2013, 11:31 PM   #15
Rewards Points: 156
How many stories is your house? When do you think your next re-roofing will be?
I was really pleased with how my project turned out. I was worried that it was going to be messier than it was. Granted it did get pretty dirty on the basement level, but for the most part I kept it contained. I'm so happy to have reclaimed this closet space. My house will be more energy efficient now too after I get this all patched up.
oh'mike (04-08-2013)
Roof leak near chimney GlennAble Roofing/Siding 23 07-22-2011 06:52 PM
gas hot water tank venting in chimney w no furnace... dbldee20 HVAC 5 02-25-2011 08:21 AM
Chimney leaking AgentW Building & Construction 43 12-23-2010 10:20 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
