I Think This Is Limestone - How To Repair? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-03-2012, 06:48 AM   #1
Question
I think this is limestone - how to repair?
Hi.
The two attached photos are of a front stoop. The building is a 120 year old Chicago 2 flat. I believe the stone is Indiana Limestone (everything else around here is at least).
I'm not sure how to approach fixing this. A few Questions-
- Will a concrete mix 'bind' to the limestone sufficiently? Is there any particular mix I should use?
- It looks like to much to quick patch. I think I need a form. Agree?
- Am I better off ripping the entire step out and replacing it? Or to ask it another way, is it worth the time / effort / hassle to remove the step?
First time post, thanks in advance for any help.
Cheers.
I think this is limestone - how to repair?-step-1.jpg   I think this is limestone - how to repair?-step-2.jpg
sdillinger is offline   Reply With Quote
Old 06-03-2012, 06:56 AM   #2
DIY staff
Rewards Points: 7,174
Could you post a picture from a bit further back--showing what is setting on top of the slab?
Replacement is the answer---any patch work will fail in a few winters time---
Old 06-03-2012, 07:46 AM   #3
As requested, oh-mike, attached are 4 more pics.
Now that I look more closely I see what is 'on top' is the building. I'm guessing the stoop sits on the the exterior brick wall, similar to the window sill in 'step 6'. Hard to know for sure.
This is a rental building, so I have a different cost / value proposition than if it were my home. I'd take major visual improvement over 50 year lifespan replacement.
Thanks again for any help!
I think this is limestone - how to repair?-step-3.jpg   I think this is limestone - how to repair?-step-4.jpg   I think this is limestone - how to repair?-step-5.jpg   I think this is limestone - how to repair?-step-6.jpg
Old 06-03-2012, 10:44 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,012
Ayuh,... For the Long term,... I'd think bustin' it out, then form, 'n pour concrete is yer answer...
Bondo is online now   Reply With Quote
Old 06-03-2012, 10:56 AM   #5
Rewards Points: 3,520
That should have been replaced when the stoop and stairs were replaced.
Canarywood1 is offline   Reply With Quote
Old 06-04-2012, 06:10 AM   #6
Unfortunately I didn't own the place when that happened. I probably wasn't even born yet.
Tags
limestone , masonry , repair , steps
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
KNOWLEDGABLE condensate advice needed Nestor_Kelebay HVAC 5 11-23-2008 07:06 PM
