Hydraulic Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-04-2012, 01:10 PM   #1
Hydraulic Concrete
I got this hydraulic cement powder, mixed with water to re-do my older concrete swimming pool... Ace Hardware recommended it. Bad idea? Or will this work ok?
I am planning to paint it with Epoxy Swimming Pool paint, I will use a primer first.
I would like to know if this should work out ok or if the GAP Hydraulic Cement wasn't right at all. Help.
PeggyAnne is offline   Reply With Quote
Old 04-04-2012, 03:32 PM   #2
concretemasonry's Avatar
Rewards Points: 2,570
If it is real hydraulic cement, it will not work as a coating. Hydraulic cement is meant to be mixed quite stiff so it can be forced into a crack or joint to confine it as it expands slightly and locks itself in place. For a surface application it would not be the right product.
Dick
concretemasonry is offline   Reply With Quote
Old 04-04-2012, 03:45 PM   #3
Ohoh,
so, if I did... well, because I did. What would be the ramifications if I paint over it?
Old 04-04-2012, 03:54 PM   #4
Hi Dick!
Umm... I already applied it to the entire 3' section of the pool and the border of the deep end...
Will this work ok if I repaint over it?
Do I have to cover it with a different product?
OR (hopefully this is not needed) do I have to remove the Hydraulic Cement...
Peggy
UPDATE: 4/16
Hello everyone... I really appreciate your insight. I could not find anyone that sells the cementitious polymer-modified mortar. After returning from a week's business trip I found the hydraulic cement cracking and pulling away. So - I removed it with some serious power washing. You were all correct, it would not have been a happy ending.
I have purchased the epoxy pool paint (expensive stuff I mix with an additive, not the cheaper paints)
Plan is to chemically clean the pool and paint when the weather warms up a bit.
Sounds right now I think...
Old 04-04-2012, 08:03 PM   #5
Rewards Points: 4,454
hydraulic has it place but not in your pool for this type repair as dick noted,,, the proper mtl is cementitious polymer-modified repair mortar,,, since you've already gone & done it, get a bag of that stuff & coat it - THEN apply your top coating ( ' paint ' )
Old 04-10-2012, 09:00 PM   #6
Rewards Points: 152
I agree with Itsreallyconc,
You needed a high strength repair mixture such as a polyaspartic epoxy based product. Hydraulic mortar would be used in applications which would be underwater. Since its already done, paint, seal and have fun in your pool. The cracks could return so you would have to repair it the right way this time. Good luck
TRUEPRO is offline   Reply With Quote
Old 04-11-2012, 06:39 AM   #7
we agree on the ' high strength repair mixture ' part but a polyaspartic & epoxy are 2 different animals - i wouldn't recommend either for underwtr application based on suitability & expense,,, when it time, find a pool supply store,,, remember cracks are repaired differently than surface distress into the conc / plaster surface coating
The Following User Says Thank You to stadry For This Useful Post:
TRUEPRO (04-11-2012)
Old 04-11-2012, 10:23 AM   #8
Rewards Points: 152
Theres a compound called rocktight... havnt used it yet. Comes in very small box and is quite pricey but is says it dries in 15 minutes and is like 5000 psi used for surface repairs. Any experience with this? The spelling might be a little different too... roctight? roktight? IDk
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
