How Would You Fill This In - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-03-2013, 10:28 PM   #1
How would you fill this in
I just bout a house a few months ago. The previous owner decided to widen the front stoop and cover one of the windows in the basement. Two cinder blocks are slightly past the wall. Hydraulic cement ?? Sorry I cant rotate the picture.
bmg97 is offline   Reply With Quote
Old 04-03-2013, 10:51 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
here you go
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
bmg97 (04-03-2013)
Old 04-04-2013, 05:11 AM   #3
Rewards Points: 4,738
brack is my hero ! i see a moderator's position in that boy's future !
Old 04-04-2013, 10:39 AM   #4
Rewards Points: 3,722
You can parge the area of the new blocks,but it won't stick to the painted blocks.
Canarywood1 is offline   Reply With Quote
Old 04-04-2013, 06:37 PM   #5
If i grind the paint off the surrounding area and coat it with a bonding agent, it should stick right ? What should i be using to fill it ?
Old 04-04-2013, 08:15 PM   #6
Use regular mortar mix,and be sure to wet the blocks before you start,or they will suck the water out of the mix and cause cracking.
Forgot to say layer your mortar about 1/8" to 1/4" thick
Old 04-04-2013, 09:04 PM   #7
Rewards Points: 236
ooops
Fix'n it is offline   Reply With Quote
Old 04-04-2013, 09:10 PM   #8
747
registered
747's Avatar
Rewards Points: 534
This is a great point. WET THE BLOCK
747 is offline   Reply With Quote
Old 04-04-2013, 09:14 PM   #9
How long should i let it dry between layers ? One day ? It will be about 2 to 3 inches deep on spots and 1/4 in other spots
Old 04-04-2013, 09:46 PM   #10
Rewards Points: 960
Remove the block and start over.
Lay from the inside and use some spacers in the joints where they are difficult to get at (the last course). Spread mortar on the area where the block will sit, then fill in what you knock off.
cleveman is offline   Reply With Quote
Old 04-05-2013, 03:57 AM   #11
hope the btm of that opening is well above grade OR its been properly wtrproofed on the exterior side,,, otherwise, expect a leaking bsmt wall in your future,,, i'd use vertical/overhead polymer-modified cementitious mtl extended w/3/8" clean aggregate & be done in a couple hours,,, no, its NOT avail @ ANY apron/vest store
Old 04-05-2013, 10:29 AM   #12
It is actually below grade. They expanded the front stoop with blue stone and it is "covered" It used to be a window back in the day. I doubt they waterproofed it correctly. I had a small leak when I first moved in and had to change the slope of the bluestone in one of the corners. I actually have to re do the front stoop and may have to do this at the same time . It does not leak at all now but looks like crap.
Old 04-05-2013, 01:43 PM   #13
A day should be okay,it bind's better when it's green.
toilet takes to long to fill lonewolf22 Plumbing 5 11-30-2011 07:03 AM
To fill, or not to fill? IRuehl Landscaping & Lawn Care 7 08-27-2011 04:30 PM
How to seal and fill sap veins before painting. fritzycat1 Painting 6 10-20-2009 11:13 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
