How Thick The Base For A Brick Walkway? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-23-2012, 10:02 AM   #1
Rewards Points: 1,062
How thick the base for a brick walkway?
Making a brick walkway around the house. 12 yrs ago, I just levelled the sand and it was OK for a few yrs, but after a while, moles, and hills, etc destroyed the integrity of the walkway. Now, have to pull up all the red beicks, and stat over.
I understand a good base is what they call crushed "fines". How thick should I make this? 3"? 4"?
Thanks.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-23-2012, 12:03 PM   #2
Civil Engineer
Rewards Points: 4,854
Typically you remove all organic soil (topsoil), and excavate down to approximately 12 inches below original grade. Then backfill with structural fill (sand, gravel, crushed stone) in compacted lifts of approximately 6 inches. The last few inches (approximately 3 inches) you use masons sand, which then forms the base for the bricks. Some people use polymeric sand between the bricks, I just use masons sand, works fine. The bricks should be tamped in place. We used this technique for a brick walk in front of our house 20 years ago, it has held up very nicely, and we live in the Northeast, subject to many freeze/thaw cycles each year, which can cause damage if the brick is improperly installed.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
noquacks (11-23-2012)
Old 11-23-2012, 01:11 PM   #3
Thaks, Daniel. Thats serious digging. I never knew. But, you think those last 3 " of the sand you say for the bricks wont be dug up by ants/moles? Thats my problem.
Also, for a walkway about 24" wide surface, how wide should I make the base? Add 3" to each side? 6"?
Old 11-25-2012, 08:27 PM   #4
Rewards Points: 1,232
I am not sure where "se" is, but normally your base will have to extend below frost line. 12" should be fine for most South Eastern states.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-25-2012, 08:32 PM   #5
Items wanted: Time
Rewards Points: 150
the frost line in michigan is 42". Should I compact a 42" base for my brick walk?
NiNe O is offline   Reply With Quote
Old 11-25-2012, 09:13 PM   #6
Civil Engineer
This is a brick walk, not the foundation for a building. If your naturally occurring soil is sandy or gravelly, there is no reason to go to 42 inches, since sandy/gravelly soil is not subject to frost heave. Neither is clay soil. Soil which is subject to frost heave is either predominantly silt or fine sand, so if you don't have that, no worries about frost heave. Even if your soil is prone to heave, it may not be worth it to excavate down to frost line and backfill with sand or gravel. Might be easier to live with the heave, your call.
As for the moles/ants, we have had no problem with them in 20 years on our brick walk in front of the house. We have plenty of moles, they dig tunnels all over the backyard, but have not bothered the front walk, not really sure why. Ants get into the sand and make little mounds, so once a year we sweep the sand back into the gaps, no problems.
Personally I can't see excavating 42 inches for a walkway, regardless of what type of soil you have, but it certainly will give you a good workout, and will completely eliminate heave to go that deep.
Old 11-25-2012, 09:16 PM   #7
Items wanted: Time
Rewards Points: 150
funny how civil engineers can't calculate sarcasm.
Old 11-25-2012, 11:05 PM   #8
Frost heave is frost heave.
Old 11-26-2012, 05:00 AM   #9
Items wanted: Time
Rewards Points: 150
The beauty of bricks, a little heave, remove problem area, smooth and flatten base, replace.
Old 01-04-2013, 11:02 PM   #10
Guywithskills
3-4" base, mixed fines with some silt, call it good, compact. Brick will flex. You dont want it to move at all, lay it over a poured concrete slab which is done in an industrial area or commercial setting... it is expensive to do this.
A little movement wont hurt.
Guywithskills is offline   Reply With Quote
Using Concrete as Paver Base? Boiler98 Landscaping & Lawn Care 4 07-27-2012 10:09 AM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
Reusing old brick for a shop bigalpha Building & Construction 12 01-20-2010 07:59 PM
Paint the brick or not? Walkway? Advice NEEDED! Carssson General DIY Discussions 24 09-08-2009 05:52 PM
