How To Secure Shed To Concrete Pad? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-03-2013, 02:41 PM   #1
Rewards Points: 113
Question
How to secure shed to concrete pad?
Hi All,
I'm planning to build a 10'x10' shed atop of an existing concrete pad. The pad was poured for the shed and is 10x10 in size, but bolts were not added during the pour. So, I'm seeking advice for methods of securing the sill plate to the concrete pad. Any ideas, recommendations, etc?
Thanks!
mklein49 is offline   Reply With Quote
Old 08-03-2013, 03:06 PM   #2
Rewards Points: 13,450
Expansion anchors, or a system like this http://www.strongtie.com/products/an...?source=asnav#
Old 08-03-2013, 03:10 PM   #3
Rewards Points: 113
If you went with the epoxy and a threaded rod, what size would you use?
I was concerned about the expansion anchors and drilling a hole near the edge of the concrete then the added pressure of the anchor.
Old 08-03-2013, 03:14 PM   #4
1/2" will work.
Old 08-03-2013, 03:18 PM   #5
Rewards Points: 113
Question
1/2" rod or hole? I've got a 20V 1/2" cordless dewalt hammer drill think that's enough to get the job done or should I rent/borrow a SDS hammer drill?
Old 08-03-2013, 04:05 PM   #6
Bill Kearney
Rewards Points: 1,174
A corded hammer drill makes it a non-issue drilling the holes. If you've got one to borrow and there's power handy then go for it. A cordless one will just take longer and likely need a recharge along the way. Were these just some smaller holes for tapcons, sure, that 20v would be fine. But maybe not for enough 1/2" holes to span the length of the walls involved. You could always give it a try first with the cordless and decide for yourself.
wkearney99 is offline   Reply With Quote
Old 08-03-2013, 08:07 PM   #7
Rewards Points: 113
Thumbs up
Thanks for all the help!
Old 08-03-2013, 08:23 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 562
I bet the hammer drill puts more stress on the concrete than expansion bolts would.... Bolts might be more economical too
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 08-04-2013, 06:19 AM   #9
Rewards Points: 4,578
IF you're using a 2x4 sole plate, wouldn't that locate your anchor holes about 1 3/4" from the pad's edge ? IF it were mine, i'd refrain from expansion anchors as they could easily cause spalls on the edge,,, i'd either use epoxy & threaded rod into a diamond bit cored hole OR use a 2x6 sole plate thereby moving holes farther away from pad's edge but i also have the tools to do that,,, IF it were me, that is
Last edited by stadry; 08-04-2013 at 07:30 AM. Reason: JOE CAPTION CAUGHT THE TYPO !
The Following User Says Thank You to stadry For This Useful Post:
mklein49 (08-12-2013)
Old 08-04-2013, 07:19 AM   #10
More like 1-3/4" not 7/8.
Old 08-04-2013, 07:29 AM   #11
TYPO 'sides, you know i ain't no carpenter
Old 08-04-2013, 07:57 AM   #12
I forgot to deduct 1/2 the diam. of the hole.
1-1/2 from the edge.
Old 08-04-2013, 08:45 AM   #13
its sunday morning, fergawdsake,,, can't we at least get a mulligan or 2 ? where's the love ?
Old 08-05-2013, 10:06 AM   #14
I used a ramset with 3" nails to secure my shed to the slab. Worked great!
-Seth
dezandseth is offline   Reply With Quote
Tags
anchors , concrete , shed
Leveling skids for a shed on a unlevel concrete foundation will02 Building & Construction 7 01-16-2012 02:58 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Wood Shed Construction- Town wants concrete pad? TJ_in_IL Building & Construction 20 07-26-2011 09:21 PM
concrete shed ramp rnoack Building & Construction 0 08-04-2010 08:33 AM
How to secure bottom of 4 X 4 post to concrete? darsunt Building & Construction 6 08-19-2009 07:36 PM
