How To Secure Door Threshold To Concrete Slab? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-25-2012, 12:19 AM   #1
Rewards Points: 682
How to secure door threshold to concrete slab?
I sometimes use those blue plastic coated bolts that you drive into holes drilled into the concrete. But they are too large, and I don't want those bolt heads sticking out of the threshold.
I heard there are nails that can be drive into concrete, are they available at hardware stores? Also if I drill a hole, can a regular screw be driven in there and hold?
darsunt is offline   Reply With Quote
Old 02-25-2012, 12:31 AM   #2
Rewards Points: 13,270
Reguler screw will not hold.
More info is needed. Tap Con screws are avalible in at least 4 differant sizes and will work fine with any threshold I've ever worked on.
Tap Cons are screws not bolts. Are you using flat head Tap Cons?
Old 02-25-2012, 03:07 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Ditto on using flat head Tapcon screws.
http://www.concretescrews.com/
The screw head can be counter bored ¼” and covered with a plug.
For installing a ¾” thick threshold a common Tapcon length is 1-3/4” or 2-1/4”.
Caution on using an extra long screw. They will break, I’ve done it.
Tapcon says the screw embedment s/b a minimum of 1”, maximum of 1-3/4”
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-25-2012, 07:24 AM   #4
DIY staff
Rewards Points: 7,174
Is this an exterior threshold?
If interior---use PL premium---drilling holes into the concrete and pounding in wood dowels will allow you to use regular wood screws---but I would not use that for an exterior install--water will eventually soften the wood plugs.
Old 02-25-2012, 12:23 PM   #5
Rewards Points: 682
I thought those blue bolts were Tap con. I better double check. I always tightened them down with a small crescent wrench.
Old 02-25-2012, 12:44 PM   #6
Yes sounds like they are, however there are different kinds, have a look to find ones that will set flush with the threshold.
chrisBC is offline   Reply With Quote
The Following User Says Thank You to chrisBC For This Useful Post:
oh'mike (02-25-2012)
Old 02-25-2012, 11:24 PM   #7
Rewards Points: 682
I got some tap cons in screw configuration. Thanks guys.
Old 02-25-2012, 11:29 PM   #8
Tom Struble's Avatar
Rewards Points: 2,002
what kind of threshold is it? wood/metal?
Tom Struble is offline   Reply With Quote
Old 02-25-2012, 11:30 PM   #9
Rewards Points: 682
metal
concrete porch slab questions Queso Bandit Building & Construction 2 06-29-2011 11:31 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Help stone over concrete slab Johnnyquest Flooring 0 05-20-2011 04:36 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
