-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   How to secure door threshold to concrete slab? (http://www.diychatroom.com/f105/how-secure-door-threshold-concrete-slab-134954/)
darsunt 02-24-2012 11:19 PM
I sometimes use those blue plastic coated bolts that you drive into holes drilled into the concrete. But they are too large, and I don't want those bolt heads sticking out of the threshold.
I heard there are nails that can be drive into concrete, are they available at hardware stores? Also if I drill a hole, can a regular screw be driven in there and hold?
joecaption 02-24-2012 11:31 PM
Reguler screw will not hold.
More info is needed. Tap Con screws are avalible in at least 4 differant sizes and will work fine with any threshold I've ever worked on.
Tap Cons are screws not bolts. Are you using flat head Tap Cons?
PaliBob 02-25-2012 02:07 AM
Ditto on using flat head Tapcon screws.
http://www.concretescrews.com/
The screw head can be counter bored ¼” and covered with a plug.
For installing a ¾” thick threshold a common Tapcon length is 1-3/4” or 2-1/4”.
Caution on using an extra long screw. They will break, I’ve done it.
Tapcon says the screw embedment s/b a minimum of 1”, maximum of 1-3/4”
oh'mike 02-25-2012 06:24 AM
Is this an exterior threshold?
If interior---use PL premium---drilling holes into the concrete and pounding in wood dowels will allow you to use regular wood screws---but I would not use that for an exterior install--water will eventually soften the wood plugs.
darsunt 02-25-2012 11:23 AM
I thought those blue bolts were Tap con. I better double check. I always tightened them down with a small crescent wrench.
chrisBC 02-25-2012 11:44 AM
Yes sounds like they are, however there are different kinds, have a look to find ones that will set flush with the threshold.
darsunt 02-25-2012 10:24 PM
I got some tap cons in screw configuration. Thanks guys.
Tom Struble 02-25-2012 10:29 PM
what kind of threshold is it? wood/metal?
darsunt 02-25-2012 10:30 PM
metal
