How To Repair Erosion Underneath Driveway - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-16-2013, 07:55 PM   #1
Rewards Points: 30
How to Repair Erosion Underneath Driveway
This pic is of our driveway. Note the erosion underneath. The erosion only extends about 6-14 inches (from left to right) underneath the slab. Beyond that, there's good, solid compacted dirt supporting the slab. There are no structural issues (cracks, etc.) above this area. Can anybody recommend the best way to fill this with rocks, gravel, concrete, etc. to keep it from eroding further and give some support to this area of the driveway? Thanks!
HomeGuy2 is offline   Reply With Quote
Old 03-16-2013, 09:30 PM   #2
Rewards Points: 12,816
Someone messed up on that one.
Should have been a turned down slab.
You also are going to have an issue with all those roots at some point, they need to go.
Old 03-16-2013, 09:42 PM   #3
Rewards Points: 3,348
First thing is to move that downspout,more than likely part of the cause of the problem,then see if those roots are alive.
Canarywood1 is offline   Reply With Quote
Old 03-16-2013, 10:51 PM   #4
Rewards Points: 30
Well, the slab's been like this for 63 years, so they didn't screw up that bad The roots are dead. Any suggestions or other observations? Thanks!
Old 03-16-2013, 10:52 PM   #5
Rewards Points: 30
Downspout is not operational and the roots are dead. Any suggestions or other observations? Thanks!
Old 03-16-2013, 11:21 PM   #6
Rewards Points: 192
I am certainly not a concrete guy but I don't see why you could not fix it by pushing in some nonshrinking grout. You should definatley add some dirt and foilage or grass to the side to prevent that from happening again.
Rick
bcgfdc3 is offline   Reply With Quote
Old 03-16-2013, 11:30 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 348
Rick
Me either- but there are ways to inject fill products under slabs- I've seen sunken sidewalks raised and leveled before.
But I agree that you should build some protection on the edge first
Old 03-17-2013, 07:12 AM   #8
Rewards Points: 4,448
no idea htf anyone could inject into an open void so howzabout a 2x4 & some dirt/gravel/#57 stone mix ? then backup the d/w edge to prevent more in the future 15min work,,, you're welcome
Old 03-17-2013, 08:55 AM   #9
Rewards Points: 414
The reason it eroded is because the shrub died. Shrub and tree roots excel in preventing erosion way better than grass roots.
To repair you'll need a form. Bury an aluminum flashing or redwood or other suitable material a couple of inches deep and about an inch from the concrete edge allowing it to extend above the bottom edge of the concrete approximately an inch.
Using a hydraulic cement such as Rockite mixed to a thin pourable consistency, about like thin pancake batter, fill the void.
After it cures add soil to the correct elevation and plant a small shrub back in the place of the dead and enjoy your drive and shrub for many more years to come. Let that old down spout likes it there so let it live where it's been happy for so long.
Old 03-17-2013, 09:32 AM   #10
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Ayuh,.... Throw some stone/ gravel down at the void, 'n chink it in with yer shovel...
Repeat til ya can't slam anymore gravel into the void...
Then top it off, 'n feather out the grade with top dirt, 'n seed it with grass to lock everything into place...
The top dirt toppin' oughta extend out say 3'-4' from the concrete, from the Top of the concrete...
A nice walkable grade drop...
Bondo is online now   Reply With Quote
Old 03-17-2013, 10:21 AM   #11
Rewards Points: 140
ya never know, maybe it is
Fix'n it is offline   Reply With Quote
Old 03-17-2013, 10:25 AM   #12
Rewards Points: 140
if that were mine , i would = dig down about 6". dig under at least 6" and out about 6". form out about 6" and about 1" above bottom of slab. put in stone, 4" perhaps. then i would pour concrete in there, working it up under as best possible.
Old 03-17-2013, 03:47 PM   #13
Rewards Points: 30
bcgfdc3, TheEplumber, itsreallyconc, Fairview, Bondo, and Fix'n it, THANKS for all your suggestions! Sure, my first thought was to just jam some gravel and concrete into the void underneath the driveway, then watch it set as I drank a few beers. But, I've usually found, more times than not, there's usually more than what meets the eye when it comes to concrete, electrical, and plumbing. Again, thanks!
Old 03-17-2013, 03:56 PM   #14
Plumber
Rewards Points: 348
You're welcome. Several times I have had to tunnel under footings to bring pipes into buildings- often times 4' deep. We would backfill and compact all we could, then use CDF (controlled density fill) on the remainder- if necessary, we'd use a concrete vibrator to fill the last of the voids. Check in to it
Illuminating a Driveway diydude1 Electrical 16 04-12-2012 09:24 PM
Driveway + Walkway buildup question r0yal Landscaping & Lawn Care 2 03-24-2012 09:42 AM
Subfloor repair Dave321 Flooring 3 09-16-2009 09:59 PM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 06:19 PM
Concrete driveway repair options monkey3605 Building & Construction 5 08-18-2006 04:15 PM
