How To Remove Tile Covered Cement Step - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-13-2014, 04:46 PM   #1
How to Remove Tile Covered Cement step
We have a screen room with a funky tile covered floor that has a step about 1/2 foot above the rest of the floor. One tile is broken revealing some 2x4's and poorly-poured concrete. WE WANT THIS OUT and we want to know if it is possible to cover the rest of the floor with some 'equalizer' to lay hard wood floor (once it dries). Is this possible? Can this be done on a low budget?
Thanks.
djdenali is offline   Reply With Quote
Old 02-13-2014, 10:45 PM   #2
Rewards Points: 13,694
Need a lot more info and some pictures.
What's under this floor you want to install hardwood on?
What do you mean by "equalizer".
Wood and concrete do not play well together, need a picture of that step.
Old 02-14-2014, 07:25 AM   #3
Rewards Points: 1,294
Probably also need a definition of "Low Budget"
danpik is offline   Reply With Quote
Old 02-14-2014, 02:48 PM   #4
more information on the tile covered step
Photos are attached. Light is less than ideal, but it should give you an idea. I am assuming the material beneath the rest of the tile matches what we can see from that one corner that is bust revealing the underneath materials.
What's under this floor you want to install hardwood on? What do you mean by "equalizer".
What we would like to do is cover up the tile with an equalizer, meaning something I have heard about that is like a liquid that one can poor over an uneven floor to fill in the low spots to make the floor level. Then, we hope to place 'snap-together' bamboo or the like flooring on top of this floor. Is this possible? Is something easier?
The step is about 3x6 and about 5 inches tall. The pictures might show how the step comes right out of the main tile floor. Things are quite funky around this old farmstead that it is uncertain what is underneath any of this stuff. It's the kind of place where you take apart something, thinking you have a simple project, and then you have a huge project...
LOW BUDGET: not really defined, but this isn't going to be a life-long residence. With all we want to do (put in windows, cover up the studs in the wall, redo the tin roof, and the floor) maybe $1000 all finished...Second hand--habitat for humanity/Restore materials whenever possible
does this help?
How to Remove Tile Covered Cement step-img_1012.jpg   How to Remove Tile Covered Cement step-img_1013.jpg   How to Remove Tile Covered Cement step-img_1015.jpg
Old 02-14-2014, 03:42 PM   #5
DIY staff
Rewards Points: 7,174
It sure looks like that landing step is an after thought and can be removed--
It's poorly constructed---which is why the equally poor tile job failed--
Get a hammer and a flat bar-----
what would you like to replace that with?
Old 02-17-2014, 03:40 PM   #6
We want to take that step out, somehow smooth out the tile of the rest of the floor (as well as the 'newly' exposed floor under the step) and put down a snap-together hardwood floor.
Old 02-17-2014, 03:54 PM   #7
Easier and cheaper to just remove the old tile.
Rent or buy an impact drill.
http://www.boschtools.com/Products/T...x?pid=11255VSR
Going to need a vapor barrier under the flooring.
Old 02-17-2014, 04:14 PM   #8
I looked at the tool. Thanks. Is it like a mini-jack hammer?
Old 02-17-2014, 09:30 PM   #9
That's right, with a wide chisel it goes pretty fast.
I'd also get some 5 gal. buckets, goggles, shop vac, knee pads.
Old 02-17-2014, 10:15 PM   #10
Msradell's Avatar
Rewards Points: 210
If this is actually a screened porch conventional snap together "hardwood" isn't going to work because it's not exterior rated. In a screened porch you are going to need to use something is rated for exterior use which can be much more expensive.
Msradell is offline   Reply With Quote
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 02:29 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Ceramic tile on a little step... kbens74 Flooring 8 01-04-2007 10:45 AM
tile step into whirlpool ekaplan1020 Remodeling 1 04-09-2006 10:48 AM
